3 Replies Latest reply on Nov 17, 2008 7:46 AM by matthewmaday
    creating check boxes
    Almudever Level 1
      Hello,
      I am searching information about check boxes for create test quetions. If need to have some examples.
      I would like one page to looking for them.
      Thank's
        • 1. Re: creating check boxes
          Level 7
          I'm not sure exactly what you're asking for.
          There are checkboxes available on the Tool Palette (press Ctrl + 7 in
          the authoring environment) under either the "default" (flash component)
          or "classic" configurations
          • 2. Re: creating check boxes
            Almudever Level 1
            I refer a some comands like hilite and others to use this check box . Or if you have any web page with an example of a test questions
            • 3. Re: creating check boxes
              matthewmaday
              I see what you are asking...
              -- To detect the state of a check box
              sprite(1).selected -- this will return boolean values (1 selected, 0 not selected)
              I created 3 functions for you which will show you how to work with check boxes.
              on QUESTION_multipleChoice pSelect, pStartSN, pEndSN
              -- this function will only allow the selection of one check box
              -- pSelect [INT] the number of the sprite that was just selected
              -- pStartSN [INT] the number of the first sprite in the range of check boxes
              -- pEndSN [INT] the number of the last sprite in the range of check boxes
              repeat with i = pStartSN to pEndSN
              sprite(i).selected = (i=pSelect)
              end repeat
              end
              on QUESTION_returnSelectedCheckboxes pStartSN, pEndSN
              -- this function will return all of the check boxes that are selected between the defined range
              pList = []
              if sprite(i).selected then append pList, i
              end repeat
              return pList
              end
              on QUESTION_clearSelectionBoxes pStartSN, pEndSN
              -- this function will set all of the check boxes, within a defined range, to not selected
              sprite(i).selected = 0
              end repeat
              end
