1 Reply Latest reply on Aug 13, 2008 12:45 PM by (Eric_Bakken)
    SDK FTP plugin fails on 2.0
      Hello -
      The FTP plugin from the SDK fails to upload from 2.0. If I try a SFTP upload, I get this error:
      Cannot upload because Lightroom could not create the destination directory.
      I get this error if there is a subdirectory to create or not. It happens if there is a trailing slash or not.
      If I try a FTP tranfer, passive or enhanced passive, I get this error:
      Unable to upload because Lightroom cannot ascertain if the target destination exists.
      If I hit Browse in the FTP settings it connects properly to the server and gives me directory listings. The same exact settings work fine in 1.4.1. I have upgraded the plugin to the one that comes with the 2.0 SDK. Anyone have any ideas?
      otto
        • 1. Re: SDK FTP plugin fails on 2.0
          I'm getting this same problem. LR can connect to my ftp through browsing for a destination folder, but gives me the error message,
          Tried different directories, tried existing directories, tried non-existing directories to see if it was trying to create a new directory...nothing works.
          Then I tried a different server...that worked.
          THEN...I THINK I GOT IT!
          It seems that the export plugin doesn't like symbolic links. on my shared hosting, I have both a directory in my home called 'www' and "public_html"
          I used public_html instead of www as the full path and the plugin worked.
          so my full path (and I just typed this manually instead of browsing for it) is:
          home/public_html/xxxx/xxxx/
          That seems to work.
