4 Replies Latest reply on Dec 16, 2008 3:24 AM by (Herb_Albert)
    [Windows, possibly bug report] LR2 spawns non-terminating cmd.exe processes
    Level 1
      Hi.
      I noticed that my system accumulates cmd.exe processes when external 'apps' other than executables (.exe) are called using the LrShell.openFilesInApp API method.
      For example:
      import 'LrShell'.openFilesInApp({ 'abc', 'def' }, '/temp/dummy.vbs')
      where dummy.vbs is an empty (or non-empty but also terminating) script. Same with .cmd (Windows batch file) or .html (document opened in browser). The files are successfully handled by their default handlers.
      I traced a LR instance using Sysinternals Process Monitor. This is the result:
      Operation: Process Create
      Result: SUCCESS
      Path: C:\WINDOWS\system32\cmd.exe
      Command line: "C:\WINDOWS\system32\cmd.exe" /k /temp/dummy.vbs abc def
      The last line reveals that the call is handed to cmd.exe. And that cmd.exe is called with the /k switch. Which is: do not terminate after execution.
      Seems like the /k switch is responsible for the stuck processes. Is this forum the right place to contact a LR developer to have a look at the issue?
      Environment is Win XP SP3, LR 2.1.
      Herb
