5 Replies Latest reply on Feb 24, 2009 8:38 PM by escouten
    Problem iterating through LR property table
    Level 1
      I'm having some difficulty and I'm not 100% sure whether it's a shortcoming in my understanding of Lua or of Lightroom's use of Lua.
      I'm writing an export service provider. I have all of my dialog controls' values bound and named with a common prefix for my provider, e.g.:
      value = bind 'myplugin_param1'
      value = bind 'myplugin_param2'
      In my processRenderedPhotos(), I need to write the values for my controls to a file. I want to iterate through the exportContext.propertyTable and if I see a key that begins with my prefix, I write the value otherwise I ignore it. Something like this:
      for k, v in pairs( exportContext.propertyTable ) do
      if (string.sub(k, 1, 9) == 'myplugin_') then
      io.write( k .. ': ' .. v .. '\n' )
      end
      end
      But this doesn't work. Digging deeper, I find that propertyTable has just two keys in it. One of them is a string "< contents >" with a value that is the table of property values I'd expect. So, changing the first line in the above code snippet to this makes it all work:
      for k, v in pairs( exportContext.propertyTable["< contents >"] ) do
      But if that's the case, I'm confused why I *can* access fields by name directly, i.e. this works correctly:
      foo = exportContext.propertyTable["myplugin_param1"]
      So, is this a Lua thing or a LR/Lua thing? Is LR playing tricks with this table's metatable to make this happen (maybe override the __index method?) ?
      I'd rather not access my properties directly by name since if I add/remove them, this is one more place in the code I need to maintain. With the code change I made above, everything works the way I prefer but it's undocumented so I'd like to know if there's a better way.
      Dave
