24 Replies Latest reply on Jun 14, 2011 6:13 AM by Jebus121
    causes of "plugin entry point could not be found"
    qu1j0t3 Level 1
      I had a report from a user of my most popular plugin (i.e., mature and extremely well tested), that it failed to work for him on Photoshop CS3 Extended + Vista Business 32-bit.
      The error message when he used the plugin was "Could not save as ... because the plugin entry point could not be found."
      Is there anything new about CS3 Ext that might cause this? (The plugin is known to be compatible with Vista.)
      I have not had other reports like this, so I am currently concluding it's an oddity of his installation.
      --Toby
        • 1. Re: causes of "plugin entry point could not be found"
          qu1j0t3 Level 1
          Turns out the problem was not the plugin, but a weird mix of UAC/Administrator/Remote Desktop... here's what the user wrote:<br /><br />> I did my testing via remote desktop, as I was no longer near the PC in question.I started by closing down photoshop, and bypassing some of the the UAC (user account control), by running the program as administrator. Since that's what messes a whole lot of other programs up, I thought 'well, you never know'. So I proceeded to make a new image, scribbled a bit on it, and attempted to save it. It actually worked. I thought this was a bit odd, and descided to reboot photoshop in normal user mode again. This time, somehow, I _could_ save as ICO again. I'm really confused about all this. Either photoshop was somehow confused by the freshly installed plugin last time, or running it as Administrator once fixed something, I really don't know. I'm in application development myself, and I really have no sensible way of explaining this behaviour. All in all, it works now. And not only via remote desktop. <br /><br />> - install plugin in the proper directory<br /><br />> - boot cs3 normally<br /><br />> - saving as ico gives 'D:\Path\thingy.ico" because the plugin entry point count not be found..' repeatably. <br /><br />> - <crying like a baby><br /><br />> - [From remote desktop]<br /><br />> - Starting photoshop as admin, which made saving work.<br /><br />> - Restarting photoshop as normal user, and saving still works<br /><br />> - [No longer on remote desktop<br /><br />> - Starting photoshop normally, and saving still works.
          • 2. Re: causes of "plugin entry point could not be found"
            qu1j0t3 Level 1
            Well now I have had many many reports. It's Vista.
            However this workaround works for most people.
            • 3. Re: causes of "plugin entry point could not be found"
              Level 1
              I tried running it as an administrator (by right-clicking the program and selecting such) and am still having the same problem. I don't have a "remote" desktop, I don't think. I am on my local computer in the livingroom. Is remote and local the same here as web definitions??? So, any suggestions? I am on Vista 32-bit, PS CS3.
              I just want to update the .ico for my website :(
              Thanks!
              Allison
              • 4. Re: causes of "plugin entry point could not be found"
                qu1j0t3 Level 1
                Try restarting Vista before reinstalling the plugin. I don't know first hand if this helps, as I don't and never will run Vista.
                • 5. Re: causes of "plugin entry point could not be found"
                  Level 1
                  Toby,
                  Thanks for the rebooting tip. I was able to save as an .ico with no error message.
                  Cheers,
                  Jacob
                  • 6. Re: causes of "plugin entry point could not be found"
                    Level 1
                    Toby,
                    I was able to correct this problem. After installing the ICO (Windows) plug-in in Vista (32 or 64-bit), the user will have to log into a Vista profile with administrator access. Navigate to the Plug-Ins > File Formats folder where the "ICOFormat.8bi" plugin is visible.
                    Right-click on the plug-in to bring up the dialog box, click properties and at the bottom of the dialog box you will notice the message "This file came from another computer and might be blocked to help protect this computer." Click "Unblock", "Apply" and restart the computer.
                    The plug-in should work after the above steps have been completed.
                    Thanks to all,
                    Jas
                    • 7. Re: causes of "plugin entry point could not be found"
                      qu1j0t3 Level 1
                      Jas, incredible. That's the first really good remedy I've seen! Thankyou.
                      • 8. Re: causes of "plugin entry point could not be found"
                        Level 1
                        Until tonight I was using .ico file format with my Vista and Photoshop CS3. Why suddenly today I am getting error message, any idea?
                        And sure, I checked and plugin, there in correct file so what is the problem? How can I fix?
                        Here is the error message:
                        "Could not sae as x.ico because the plugin entry point could not be found."
                        Thanks from now
                        Linda
                        • 9. Re: causes of "plugin entry point could not be found"
                          qu1j0t3 Level 1
                          Linda, Try the recipe immediately above.
                          Failing that, try restarting Windows and reinstalling.
                          I'm beginning to wonder if this problem affects this particular plugin more than others...
                          • 10. Re: causes of "plugin entry point could not be found"
                            Level 1
                            Hi Toby,
                            I tried 3 times again tonight and tired of really; and still getting same error :(
                            Give me some idea what can I do?
                            Best,
                            Linda
                            • 11. Re: causes of "plugin entry point could not be found"
                              qu1j0t3 Level 1
                              Ditch Vista.
                              But which did you try? The recipe above, or reboot then reinstall? Those are the only 2 things I've heard of which fix the error.
                              • 12. Re: causes of "plugin entry point could not be found"
                                Level 1
                                I tried reboot then reinstall, because above recipe not matching with me, I checked for trying that above recipe too but not any message for about blocking etc, so above recipe not for me...
                                Interesting Part is my ICO FORMAT Plug-in, until last night was working perfectly with same Vista same computer. I added some new Brushes and Styles last few days, I don't think this can effect but again wonder, is that possible to something effect that, because of I added 200 - 300 new brushes/styles and now ICO FORMAT Plug-in not working??
                                If anybody has any idea, please share with me...
                                Best,
                                Linda
                                • 13. Re: causes of "plugin entry point could not be found"
                                  Level 1
                                  Or Vista or Photoshop CS3 did any updates these days, so was that effected the ICO FORMAT Plug-in?
                                  • 14. Re: causes of "plugin entry point could not be found"
                                    qu1j0t3 Level 1
                                    This problem has been reported since Vista arrived. I don't run it so I can't test directly.
                                    • 15. Re: causes of "plugin entry point could not be found"
                                      Level 1
                                      Hey, for those that dont have the "unblock" dialog, I have another solution that is pretty much the same but worked for me.
                                      - click properties on the icoformat.8bi file
                                      - click on the security tab
                                      - click on the Users, then the advanced tab
                                      - although it might say allow next to users, you still have other options you have to check.
                                      - click on users again, click edit
                                      - another box that pretty much looks the same will pop up,
                                      - click users again, click edit
                                      - click Allow on the first checkbox that says 'Full Control'
                                      - Click ok through all boxes
                                      - be sure to restart computer or changes will not take effect
                                      - open photoshop and try saving. it worked for me.
                                      Please let us know if this solution helped anyone, so we can help assist others.
                                      -Alban
                                      • 16. Re: causes of "plugin entry point could not be found"
                                        Level 1
                                        Alban,
                                        Thanks for your help but unfortunatelly not worked for me....
                                        But again thanks for sharing your experience with us...
                                        Best,
                                        Linda
                                        • 17. Re: causes of "plugin entry point could not be found"
                                          qu1j0t3 Level 1
                                          Hi, if anyone hits this "plugin entry point not found" issue with the ICO Format plugin, please download this new build (made with Visual C++ 2008) and see if it resolves the problem:
                                          http://telegraphics.com.au/sw/files/ICOFormat-1.8f5-win.zip
                                          • 18. Re: causes of "plugin entry point could not be found"
                                            qu1j0t3 Level 1
                                            Haha, thanks very much Microsoft.
                                            After spending a day installing the latest Visual C++ 2008 Express and Windows SDK, etc, the build I made (linked above) is apparently still not problem free.
                                            I have a user report that it crashes on XP SP3 + CS3.
                                            Is it in fact possible to reliably support all permutations of Windows? Anyone know how?
                                            • 19. Re: causes of "plugin entry point could not be found"
                                              Level 1
                                              Jas and Alban, I had to use both your solutions to get it to work, plus a little extra.
                                              http://www.adobeforums.com/webx?224@@4acff5cb@.3bc4549f/5
                                              http://www.adobeforums.com/webx?224@@4acffd9c@.3bc4549f/14
                                              I had to check the "Unblock" under Properties and follow Alban's steps under the Security tab. And yes, you will keep going through User pop ups that all look the same and keep checking "full control". However, I also had to add a new user, which was my computer login account and give it "full control" and that's what made it finally work.
                                              Thanks for the help! I was beginning to think this wouldn't work on Vista!
                                              • 20. Re: causes of "plugin entry point could not be found"
                                                JohnDoe10 Level 1
                                                This solution appears to work at first, but all it does for me is
                                                crash CS4 every time I try to save in .ico format.
                                                Message was edited by: JohnDoe10
                                                Ok this solution worked for me once I rebooted Thanks qu1j0t3's
                                                • 21. Re: causes of "plugin entry point could not be found"
                                                  Rookie Dezines Level 1
                                                  G'Day All,
                                                  I am currently working with Photoshop CS4  on Windows XP SP3.  After reading through each of the noted solutions, I have tried each one until I found a solution that was viable.   Although I have two units with the same OS and application, the solution  that worked for me on the unit that was experiencing the issue was installing the new *.ico application.  After the first use, it worked; but the second use crashed the application.  After a reboot, it seems to work fine.
                                                  Thank you all for your efforts in helping resolve this issue.  I hope this information helps someone else.
                                                  Regards,
                                                  Rob
                                                  • 22. Re: causes of "plugin entry point could not be found"
                                                    JoeJohnson3rd Level 1
                                                    Jas_Smith workaround above in this thread worked as a charm for me, greeeeeat! Thx a lot!
                                                    • 23. Re: causes of "plugin entry point could not be found"
                                                      cody.hayes Level 1
                                                      Today is 4/11/2011.
                                                      I used the .ico plugin 4 days ago without any problem.
                                                      Then, suddenly tonight it would not work.
                                                      The post above by "Jas_" correctly identifies the problem as a "file permission issue".
                                                      I am running Windows 7 64 bit with Photoshop Elements 7.0 and this version of the .ico format plugin.
                                                      For some reason the "permissions" for the group "Users" on the ICOFormat.8bi file (located at: \Adobe\Photoshop Elements 7.0\Plug-Ins\File Formats\ICOFormat.8bi) were "read and execute", but not "Full control".  once I changed the settings back and restarted the computer, I was able to "save as .ico" again with no problem.
                                                      (mostly) STEP BY STEP INSTRUCTIONS for Windows 7:
                                                      1. Locate your "ICOFormat.8bi" file
                                                      • Navigate to Drive Letter (usually C:), Program Files, Adobe, Adobe Elements (what ever version you are using), Plug-Ins, File Formats, and voila... ICOFormat.8bi should be in this folder. (if it is not, then the plugin is not installed, or not installed correctly (see this link to install))
                                                      2. Right Click the ICOFormat.8bi File and select Properties.
                                                      3. Select the Security Tab
                                                      4. Click the "Edit" button beneath the "Group or user names:" box.
                                                      5. Click on each group and determine whether the "full control" check box is checked in the "allow" column.
                                                      • In my case, the "users" group was allowed to "read and execute", but did not have "full control"
                                                      6. If each group does not have "full control", then Click the "allow" box next to "full control" (as long as you're not trying to prohibit a user from using this plugin, that is... >:-)
                                                      7. Apply All Changes.
                                                      8. Restart your computer.
                                                      9. Open you would-be favicon in Photoshop Elements
                                                      10 File, Save as -- .ico...   Poof!   Done!  Fixed!  Yaay!
                                                      • 24. Re: causes of "plugin entry point could not be found"
                                                        Jebus121 Level 1
                                                        Hey Guys,
                                                        I recently went through all this fun stuff, and noticed I was only able to open as an ICO...
                                                        Did anyone who is having issues saving it make sure that the file is under 150pixels resolution?
                                                        Worked for me...
                                                        Thanks.
