2 Replies Latest reply on Aug 21, 2008 3:38 AM by (chhaya_pandey)
    downloading from catalogue to dvd - only allows cd download
      Just started using - works well until I want to download to external medium:
      whether I go through File or Share, the choice is only to "burn to cd", and if I follow that route, the "Burn to cd" page option to select a drive only shows my CD drive (D) and cannot be altered to E, my DVD drive.
      Any bright ideas, anyone ?
      Thanks, adj
        • 1. Re: downloading from catalogue to dvd - only allows cd download
          Level 1
          Hi adj,
          Well, actually for burning, I don't use this software. I just third
          party burning software. I don't mind giving you some ideas, but don't
          want to come across as "selling" it either. Let me know.
          As to external medium, this software is very limited. It basically just
          categorizes the images. The upgrade allows you to move them around from
          the organizer view as well as edit. On the other hand, you could also
          just store them on an external drive (which is what I do) and then
          search and add it to the catalog.
          The thing about the full version is that it is a very powerful image
          editor, which clearly is not available in this one. You might look at
          the trial version to see if that is what you need. Keep in mind, if you
          use the trial, any changes to images will not be seen by PSA because PSE
          makes a completely new catalog.
          In both packages, they don't actually change the original, they change a
          copy.
          Cheers
          • 2. Re: downloading from catalogue to dvd - only allows cd download
            Level 1
            Hello adj,
            As suggested by Jim, the facility for burning to DVD is not available in this software.
            Cheers,
            Chhaya
