2 Replies Latest reply on Oct 5, 2005 12:23 PM by (Julie_Sabuda)
    Can't get PSA SE 3.0 to close/exit
      When I try to exit PSA SE 3.0 it brings up a small status window stating "Completing Pending Operations..." 20%. It never gets further than 20% and will not close the application. The application is not hung for I can click "Return to application" and it will promptly do so.
      Thanks for any input or suggestions.
        • 1. Re: Can't get PSA SE 3.0 to close/exit
          smriti mehra Adobe Employee
          Hi Julie,
          I have also seen this window but it disappeared after the pending operation was completed. It generally occurs when the application is busy generating previews/thumbnails of the photos or any other pending operation. This window should disappear after sometime.Does this happen in your case, or it remains there forever?
          Smriti
          • 2. Re: Can't get PSA SE 3.0 to close/exit
            Level 1
            Hi Smriti,
            Thanks for your input.
            Earlier in the day I did up load 500+ images. That evening I let the application sit in the pending operation mode for at least an hour. A few days later my DH ended up doing an 'end task' on the application so he can run another application. I now am able to open and exit successfully but I haven't up loaded additional images. When I do and if I get that message again I will let the application work at it for a while longer.
            Regards,
            Julie
