1 2 Previous Next 72 Replies Latest reply on Oct 3, 2006 6:31 PM by Newsgroup_User
    Passing values from mc to mc/instance to instance
    disco-logic Level 1
      Ive made a new topic for this cos the last one went wildly off-topic...
      Im trying to use info from the soldier instance to set up bullets he fires.
      Each new bullet wants to be its own instance/mc whatever. Thing is that I cant get the info out of _root.soldier and into _root.bulletX (where X is an arbitary value)
      there is code in the bullet onClipEvent(load) like
      this._rotation = soldier1._rotation;
      Which by the looks of some traces Ive done just gives soldier._rotation as undefined.
      How can I pass a value out of soldier to use here?
        • 1. Re: Passing values from mc to mc/instance to instance
          crazyjoemilan Level 2
          this._rotation = whatever. //defines this._rotation, it does not define "whatever"
          soldier1._rotation = whatever //defines soldier1._rotation.
          X = Y //defines X using Y.
          Y = X //defines Y using X.
          does that help?
          • 2. Re: Passing values from mc to mc/instance to instance
            disco-logic Level 1
            hmm afraid that the kind of code I was using. The problem is you cant take a variable out of one instance and use it in another.
            I know that soldier1._rotation is working cos it work for soldier clip.
            The problem comes when you want to pass soldier1._rotation onto the bullet cos a statement like
            bullet._rotation = soldier1._rotation;
            within the code for the bullet will simply decide that it cant find soldier1._rotation. What I think I need is a way to make the value public
            • 3. Re: Passing values from mc to mc/instance to instance
              Level 7
              "disco-logic" <webforumsuser@macromedia.com> wrote in message
              news:efk7gi$2f1$1@forums.macromedia.com...
              > take a
              > cos
              > a statement like
              okay, here is what you want to check (for this case and any case when you
              have some issue like this --- unexpected behavior)
              TRACE, TRACE, TRACE.
              Each bullet is coming from an attachMovie or a duplicateMovieClip, right???
              In either case, in your code you have:
              onClipEvent(load) {
              this._rotation = solder1._rotation;
              which is a valid statment. This says, find the rotation value of soldier1
              and assign it to this (the Bullet clip)
              So, TRACE...
              add
              trace(soldier1._rotation);
              to the onClipEvent(load) handler above. You see that soldier1._rotation is
              undefined.
              next add another TRACE...
              add
              trace(this);
              to the handler.
              You will see that 'this' is referring to your bullet. But, soldier1 is not
              in the bullet instance, it is in the _parent instance (most likely - depends
              on your setup) so, you should try
              onClipEvent(load) {
              this._rotation = _parent.soldier1._rotation;
              if that doesn't work, add the following traces and post their output
              trace(this);
              trace(this._parent);
              arbitary value)
              undefined.
              • 4. Re: Passing values from mc to mc/instance to instance
                Level 7
                > take a
                > cos
                > a statement like
                onClipEvent(load) {
                So, TRACE...
                add
                undefined.
                add
                trace(this);
                to the handler.
                onClipEvent(load) {
                trace(this);
                arbitary value)
                undefined.
                • 5. Re: Passing values from mc to mc/instance to instance
                  disco-logic Level 1
                  does _parent refer to the mc that "gave birth" to the new instance?
                  so if duplicateMoveClip(..."bullet"...) is in soldier1 will the _parent of bullet be soldier1? or will it be the original bullet Im duplicating?
                  Also my traces threw up odd results. I got the rotation to work but not the _x and _y positions. Odd.
                  I think I might start using proper .as scripts and define everything as classes cos this is getting too confusing using mc instances with code inside them.
                  • 6. Re: Passing values from mc to mc/instance to instance
                    Level 7
                    news:efkdr8$95f$1@forums.macromedia.com...
                    if you are using duplicateMovieClip, then the _parent is the same for all
                    duplicated bullets... the holder of the original bullet. So, if the bullet
                    instance is inside of your soldier1 MC then the _parent of each duplicated
                    bullet will be the soldier1.
                    > the
                    What are the outputs of your 'odd results'... if _x and _y don't work, TRACE
                    'em.
                    trace(this._parent._x);
                    trace(this._parent._y);
                    > inside
                    > them.
                    This is my preferred way to go.
                    • 7. Re: Passing values from mc to mc/instance to instance
                      Level 7
                      > take a
                      > cos
                      > a statement like
                      onClipEvent(load) {
                      So, TRACE...
                      add
                      undefined.
                      add
                      trace(this);
                      to the handler.
                      onClipEvent(load) {
                      trace(this);
                      arbitary value)
                      undefined.
                      • 8. Re: Passing values from mc to mc/instance to instance
                        Level 7
                        > the
                        'em.
                        > inside
                        > them.
                        • 9. Re: Passing values from mc to mc/instance to instance
                          Level 7
                          > take a
                          > cos
                          > a statement like
                          onClipEvent(load) {
                          So, TRACE...
                          add
                          undefined.
                          add
                          trace(this);
                          to the handler.
                          onClipEvent(load) {
                          trace(this);
                          arbitary value)
                          undefined.
                          • 10. Re: Passing values from mc to mc/instance to instance
                            Level 7
                            > the
                            'em.
                            > inside
                            > them.
                            • 11. Re: Passing values from mc to mc/instance to instance
                              Level 7
                              > take a
                              > cos
                              > a statement like
                              onClipEvent(load) {
                              So, TRACE...
                              add
                              undefined.
                              add
                              trace(this);
                              to the handler.
                              onClipEvent(load) {
                              trace(this);
                              arbitary value)
                              undefined.
                              • 12. Re: Passing values from mc to mc/instance to instance
                                Level 7
                                > the
                                'em.
                                > inside
                                > them.
                                • 13. Re: Passing values from mc to mc/instance to instance
                                  Level 7
                                  > take a
                                  > cos
                                  > a statement like
                                  onClipEvent(load) {
                                  So, TRACE...
                                  add
                                  undefined.
                                  add
                                  trace(this);
                                  to the handler.
                                  onClipEvent(load) {
                                  trace(this);
                                  arbitary value)
                                  undefined.
                                  • 14. Re: Passing values from mc to mc/instance to instance
                                    Level 7
                                    > the
                                    'em.
                                    > inside
                                    > them.
                                    • 15. Re: Passing values from mc to mc/instance to instance
                                      Level 7
                                      > take a
                                      > cos
                                      > a statement like
                                      onClipEvent(load) {
                                      So, TRACE...
                                      add
                                      undefined.
                                      add
                                      trace(this);
                                      to the handler.
                                      onClipEvent(load) {
                                      trace(this);
                                      arbitary value)
                                      undefined.
                                      • 16. Re: Passing values from mc to mc/instance to instance
                                        Level 7
                                        > the
                                        'em.
                                        > inside
                                        > them.
                                        • 17. Re: Passing values from mc to mc/instance to instance
                                          Level 7
                                          > take a
                                          > cos
                                          > a statement like
                                          onClipEvent(load) {
                                          So, TRACE...
                                          add
                                          undefined.
                                          add
                                          trace(this);
                                          to the handler.
                                          onClipEvent(load) {
                                          trace(this);
                                          arbitary value)
                                          undefined.
                                          • 18. Re: Passing values from mc to mc/instance to instance
                                            Level 7
                                            > the
                                            'em.
                                            > inside
                                            > them.
                                            • 19. Re: Passing values from mc to mc/instance to instance
                                              Level 7
                                              > take a
                                              > cos
                                              > a statement like
                                              onClipEvent(load) {
                                              So, TRACE...
                                              add
                                              undefined.
                                              add
                                              trace(this);
                                              to the handler.
                                              onClipEvent(load) {
                                              trace(this);
                                              arbitary value)
                                              undefined.
                                              • 20. Re: Passing values from mc to mc/instance to instance
                                                Level 7
                                                > the
                                                'em.
                                                > inside
                                                > them.
                                                • 21. Re: Passing values from mc to mc/instance to instance
                                                  Level 7
                                                  > take a
                                                  > cos
                                                  > a statement like
                                                  onClipEvent(load) {
                                                  So, TRACE...
                                                  add
                                                  undefined.
                                                  add
                                                  trace(this);
                                                  to the handler.
                                                  onClipEvent(load) {
                                                  trace(this);
                                                  arbitary value)
                                                  undefined.
                                                  • 22. Re: Passing values from mc to mc/instance to instance
                                                    Level 7
                                                    > the
                                                    'em.
                                                    > inside
                                                    > them.
                                                    • 23. Re: Passing values from mc to mc/instance to instance
                                                      Level 7
                                                      > take a
                                                      > cos
                                                      > a statement like
                                                      onClipEvent(load) {
                                                      So, TRACE...
                                                      add
                                                      undefined.
                                                      add
                                                      trace(this);
                                                      to the handler.
                                                      onClipEvent(load) {
                                                      trace(this);
                                                      arbitary value)
                                                      undefined.
                                                      • 24. Re: Passing values from mc to mc/instance to instance
                                                        Level 7
                                                        > the
                                                        'em.
                                                        > inside
                                                        > them.
                                                        • 25. Re: Passing values from mc to mc/instance to instance
                                                          Level 7
                                                          > take a
                                                          > cos
                                                          > a statement like
                                                          onClipEvent(load) {
                                                          So, TRACE...
                                                          add
                                                          undefined.
                                                          add
                                                          trace(this);
                                                          to the handler.
                                                          onClipEvent(load) {
                                                          trace(this);
                                                          arbitary value)
                                                          undefined.
                                                          • 26. Re: Passing values from mc to mc/instance to instance
                                                            Level 7
                                                            > the
                                                            'em.
                                                            > inside
                                                            > them.
                                                            • 27. Re: Passing values from mc to mc/instance to instance
                                                              Level 7
                                                              > take a
                                                              > cos
                                                              > a statement like
                                                              onClipEvent(load) {
                                                              So, TRACE...
                                                              add
                                                              undefined.
                                                              add
                                                              trace(this);
                                                              to the handler.
                                                              onClipEvent(load) {
                                                              trace(this);
                                                              arbitary value)
                                                              undefined.
                                                              • 28. Re: Passing values from mc to mc/instance to instance
        Level 7
        > the
        'em.
        > inside
        > them.
        • 29. Re: Passing values from mc to mc/instance to instance
        Level 7
        > take a
        > cos
        > a statement like
        onClipEvent(load) {
        So, TRACE...
        add
        undefined.
        add
        trace(this);
        to the handler.
        onClipEvent(load) {
        trace(this);
        arbitary value)
        undefined.
        • 30. Re: Passing values from mc to mc/instance to instance
        Level 7
        > the
        'em.
        > inside
        > them.
        • 31. Re: Passing values from mc to mc/instance to instance
        Level 7
        > take a
        > cos
        > a statement like
        onClipEvent(load) {
        So, TRACE...
        add
        undefined.
        add
        trace(this);
        to the handler.
        onClipEvent(load) {
        trace(this);
        arbitary value)
        undefined.
        • 32. Re: Passing values from mc to mc/instance to instance
        Level 7
        > the
        'em.
        > inside
        > them.
        • 33. Re: Passing values from mc to mc/instance to instance
        Level 7
        > take a
        > cos
        > a statement like
        onClipEvent(load) {
        So, TRACE...
        add
        undefined.
        add
        trace(this);
        to the handler.
        onClipEvent(load) {
        trace(this);
        arbitary value)
        undefined.
        • 34. Re: Passing values from mc to mc/instance to instance
        Level 7
        > the
        'em.
        > inside
        > them.
        • 35. Re: Passing values from mc to mc/instance to instance
        Level 7
        > take a
        > cos
        > a statement like
        onClipEvent(load) {
        So, TRACE...
        add
        undefined.
        add
        trace(this);
        to the handler.
        onClipEvent(load) {
        trace(this);
        arbitary value)
        undefined.
        • 36. Re: Passing values from mc to mc/instance to instance
        Level 7
        > the
        'em.
        > inside
        > them.
        • 37. Re: Passing values from mc to mc/instance to instance
        Level 7
        > take a
        > cos
        > a statement like
        onClipEvent(load) {
        So, TRACE...
        add
        undefined.
        add
        trace(this);
        to the handler.
        onClipEvent(load) {
        trace(this);
        arbitary value)
        undefined.
        • 38. Re: Passing values from mc to mc/instance to instance
        Level 7
        > the
        'em.
        > inside
        > them.
        • 39. Re: Passing values from mc to mc/instance to instance
        Level 7
        > take a
        > cos
        > a statement like
        onClipEvent(load) {
        So, TRACE...
        add
        undefined.
        add
        trace(this);
        to the handler.
        onClipEvent(load) {
        trace(this);
        arbitary value)
        undefined.
        1 2 Previous Next
