2 Replies Latest reply: Jun 19, 2006 12:48 PM by Jean- Pierre Lemonde RSS
    Changes in slide show on DVD
    Jean- Pierre Lemonde Community Member
      1.I made a slide show with Photoshop Elements 4 and burn it to a DVD-RW with Premiere Elements. After several try it works.All 750 photos with transitions are there and I saw it on T.V.
      2 Back in PE4, I made some changes in the slideshow and save it.I understand these changes are not automatically transfer in Premiere.
      3.Question:how can I also modify the version in Premiere?Do I have to start all over again and burn a new DVD or is there another way to do it.?
      4.Question: looking the DVD in Premiere I noticed many photos are missing in the assembly at the bottom of the screen but I can view all in the center of the screen.Why?
      Thanks for help.
        • 1. Re: Changes in slide show on DVD
          Barb__O Community Member
          I think that the simplest approach will be to burn a new DVD using the same process from PSE 4. You say you used a DVD-RW so I think you can burn again on the same disc; I have done it with a DVD+RW.
          In theory you could modify the Premiere Elements timeline to reproduce the same changes that you made in the PSE 4 slideshow - but you would still need to burn to DVD again. If do you start again from PSE 4 then I think you will need to redo any DVD menus you made in PE2.
          When you look at your show in Premiere, it has already been made in to a video so they are no longer individual slides. I suspect that the fact that you are not seeing all of the photos is because of the scale that is being used by default to display the timeline of the video in Premiere Elements. If you zoom in on that timeline, I think you should be able to see individual photos. I think that there is a scale setting that you can change for the timeline - but I don't immediately recall what it is.
          For more detailed answers to these questions you might try the Premiere Elements forum because there are multiple participants on that forum who know PSE 4 and PE2.
          http://www.adobeforums.com/cgi-bin/webx?14@@.3bb574e6
          • 2. Re: Changes in slide show on DVD
            To Barb.Olson
            Thank you for you good answer.
