4 Replies Latest reply on Nov 19, 2008 6:43 AM by phthanh
    Problem with HTTPService
    phthanh
      Hi all,
      I'm having a problem with HTTPService
      I have the file named "a.mxml" which contains a HTTPService that calls to a url: " http://localhost:8080/onlineshop.php". This php file will read the MySQL database and return a result in XML format. As you know, the file "a.mxml" will read this XML result and display it on the webpage. But the problem is when I move the "bin-debug" folder to another place rather than its original place and I run the a.swf file (the result of the file a.mxml), it can't access the MySQL database and sent an error message:
      "[RPC Fault faultString="Security error accessing url" faultCode="Channel.Security.Error" faultDetail="Destination: DefaultHTTP"]
      at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::faultHandler()[E:\dev\3.1.0\frameworks\project s\rpc\src\mx\rpc\AbstractInvoker.as:218
      at mx.rpc::Responder/fault()[E:\dev\3.1.0\frameworks\projects\rpc\src\mx\rpc\Responder.as:53 ]
      at mx.rpc::AsyncRequest/fault()[E:\dev\3.1.0\frameworks\projects\rpc\src\mx\rpc\AsyncRequest .as:103]
      at DirectHTTPMessageResponder/securityErrorHandler()[E:\dev\3.1.0\frameworks\projects\rpc\sr c\mx\messaging\channels\DirectHTTPChannel.as:368]
      at flash.events::EventDispatcher/dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at flash.net::URLLoader/redirectEvent()"
      I've added a crossdomain.xml file right in the bin-debug folder, and I wrote this in that file:
      <?xml version="1.0"?>
      <!DOCTYPE cross-domain-policy SYSTEM " http://www.macromedia.com/xml/dtds/cross-domain-policy.dtd">
      <cross-domain-policy>
      <allow-access-from domain=" http://127.0.0.1:8080/" secure="false"/> <!--i grant access to my local apache site for the swf file-->
      </cross-domain-policy>
      but it still doesn't work
      Do you guys have any ideas with this error?
      Please help !
      Thanks with regards
      P/S: Please forgive for my bad English :-)
