1 2 Previous Next 40 Replies Latest reply: Jan 26, 2009 9:48 AM by Ramón G Castañeda RSS
    CS4 3D, an inauspicious beginning
    Welles Goodrich Community Member
      Just got PS CS4. Installed without problem. I thought I'd open a 3D layer of a 28MB OBJ file without materials applied. The same file opens in a 3D layer just fine in CS3 though it takes 15 seconds or so. In CS4 it hangs and eventually the app has to be force quit. Not a great start.
        • 1. Re: CS4 3D, an inauspicious beginning
          Ann Shelbourne Community Member
          Does your video card have 256 MB VRAM, and does it support OpenGL in CS4?
          Check you prefs to see that you have enabled OpenGL Drawing.
          • 2. Re: CS4 3D, an inauspicious beginning
            Community Member
            initialize, zero write, install from scratch, remove all 3rd party ram PCI cards and hardware
            • 3. Re: CS4 3D, an inauspicious beginning
              Yep, ATI Radeon X1900 (512mb vram) Open GL Engine detected by the program upon installation and checked automatically. I went through the prefs at first startup, prior to any actions.
              • 4. Re: CS4 3D, an inauspicious beginning
                No. That's shooting a mosquito with an elephant gun.
                • 5. Re: CS4 3D, an inauspicious beginning
                  I've successfully loaded several 3D OBJ files with simpler geometry, the largest 6 mb which does roughly relate to the number of polys. I'm going to try and simplify my first model and see if it loads.
                  • 6. Re: CS4 3D, an inauspicious beginning
                    Well, there's good news and bad news. The good news is that I tried loading that 28mb model and then went off and worked elsewhere for a half an hour or so. I checked in on PS and found it had loaded sometime during that extended period. The bad news is that PS CS4 doesn't seem to work well at all with large model files while it seems to work fine if the model is under 10mb.
                    • 7. Re: CS4 3D, an inauspicious beginning
                      It might be that you need an even more powerful video card than yours for these large files?
                      What happens if you deselect some of the options in the Advanced section of the OpenGL Prefs.; or if you turn OpenGL off and work in Software rendering as you did in CS3?
                      [These are only wild suggestions because i have little experience in advanced 3D modelling.]
                      • 8. Re: CS4 3D, an inauspicious beginning
                        I don't believe it has anything to do with the vid card, Ann, though that isn't an unreasonable suggestion. My belief is founded on the fact that the file opens just fine in CS3. If you actually needed a $1,500 to $2,500 video card to use Photoshop's 3D tools they are useless.
                        From my perspective, Photoshop made an attempt to enter the 3D world in CS3, sort of dipping it's toes in the water in a manner of speaking. I thought the tools were barely useful and almost never used them after early experimentation. All the functions which Adobe offered are better implemented in 'real' 3D apps.
                        I had hoped that the 3D tools would be significantly more valuable in CS4. There certainly are more tools available but the implementation is pretty crude. After seeing Adobe trying two sets of 3D tools, I think they might just as well drop it. They aren't a professional addition but more a toy although I'm sure some people will find use for them and others will praise them to the skies.
                        • 9. Re: CS4 3D, an inauspicious beginning
                          Chris Cox Adobe Employee
                          Welles - would you be willing to send that file to Adobe so we can try to reproduce the problem? It could be a number of things (pathological case in the file, a bug in our code, or a bug in the OpenGL driver) making it take that long.
                          We have been working with multi-million polygon files on cards similar to yours.
                          • 10. Re: CS4 3D, an inauspicious beginning
                            Hi Chris,
                            I'd be glad to do so. It was a model originally made in XenoDream and I made it so can give you the rights to use it any way you want. You can download it from my iDisk.
                            http://homepage.mac.com/wellesgoodrich/FileSharing2.html
                            The file is Widget2.obj.zip
                            I do hope you find something was wrong with my file as I would love to be able to do quick 3D composite work right in Photoshop rather than render whole images all the time.
                            • 11. Re: CS4 3D, an inauspicious beginning
                              Alright, got the file. Our 3D engineers will be looking at it shortly.
                              • 12. Re: CS4 3D, an inauspicious beginning
                                SG... Employee Hosts
                                Hi Welles,
                                A quick note that the file opens and is fairly responsive for me on MacPro with Radeon HD 3870 and Vista64 with GeForce 8800 GT (granted newer cards then the X1900). Are you using a G5 or MacPro?
                                • 13. Re: CS4 3D, an inauspicious beginning
                                  Hi Steve,
                                  MacPro Dual-Core Intel Xeon 2.6GHz (2006) with an ATI Radeon X1900XT 512mb VRAM, 12mb RAM, 200GB partition on a separate HD for primary scratch. Mac OS 10.5.5 (9F33). Though it doesn't really matter, the model was exported from XenoDream 2.1 and works with Vue 6 Infinite and has been rendered with Maxwell Render on a PC by a friend.
                                  • 14. Re: CS4 3D, an inauspicious beginning
                                    Cindy- Community Member
                                    For whatever it is worth, it hangs when I try to open it too.
                                    MacPro Dual-Core Intel Xeon 2.6GHz (2006) with an NVIDIA GeForce 7300 GT 5mb RAM which is not as powerful as yours. Running OS 10.4.11
                                    • 15. Re: CS4 3D, an inauspicious beginning
                                      Hey Cindy,
                                      Thanks for trying it out. That's a little more data for the engineers. Just for fun, this was a silly render made in Vue as a test of that model.
                                      http://homepage.mac.com/wellesgoodrich/Artifact.jpg
                                      • 16. Re: CS4 3D, an inauspicious beginning
                                        WOW!
                                        That is way above my pay-grade!
                                        [ I did try to open your 3D object in CS4 but my System was not up to it either.]
                                        • 17. Re: CS4 3D, an inauspicious beginning
                                          Just silly stuff, Ann. Let me show you what a friend did with it. We've been going back and forth for a couple of days doing stupid stuff with that model. I think this one is particularly funny.
                                          http://homepage.mac.com/wellesgoodrich/WhatIsIt.jpg
                                          • 19. Re: CS4 3D, an inauspicious beginning
                                            Community Member
                                            Hey Welles, it worked for me. Opened in about one minute on a MBP 2ghz CoreDuo with 2gb ram andRadeon X1600 with 128mb Vram.
                                            • 20. Re: CS4 3D, an inauspicious beginning
                                              OK I've finally got the limitations on my Mac Pro pretty well dialed in. Any OBJ under 10mb or so opens up quite rapidly and the tools work well. It is actually better than my original gripe expressed. Unfortunately the first file I tried seemed to freeze PS CS4 simply because it was loading sloooowly and the day before I had loaded it in PS CS3 in 15 seconds (plus the app icon in the dock said Application Not Responding... I should know better).
                                              Anyway that model does load in about 5.5 minutes and does work but, again, sloowly. So I'd suggest that people stay away from really large OBJ files in Photoshop's CS4 3D capacities to gain the full utility of the tools. For lots of folks they will still be valuable. For me I think I'll mostly use PS for mats, depth and bump maps and so forth (and of course all the 2D image manips) but render 3D and image composites in Vue where I can billboard images and place models to render.
                                              Though in a sense this doesn't belong in this thread there are some wonderful new features in PS CS4. Just the capacity to see a well rendered image at 51.86% zoom is worth the buy-in!
                                              • 21. Re: CS4 3D, an inauspicious beginning
                                                That's really cool Welles!
                                                • 22. Re: CS4 3D, an inauspicious beginning
                                                  Wade S Zimmerman Community Member
                                                  Steve, the same problem I think I mentioned this to already. I have even updated my card to the nvidia GeForce 8800GT 512 MB VRAM still hangs.
                                                  Althoug I was able to open a fie that is 34.1 MB in a bout ten-fifteen seconds or so.
                                                  The speed s a bit slow. It has t perfor better I cannot open that file at all.
                                                  BTW Welles I do not think that PS is a #D authoring tool in the sense that you would use a 3D dedicated application for but rather a way in which to edit, manipulate and composite 3D objects for use with images, the insistence that this can be done better in 3D dedicated programs is out of context.
                                                  A 3D space is an important tool for image editing as many people that use and create 3D objects and compositions composite that work with images for 2D presentation as well as animated videos.
                                                  It may not be what you expect of 3D tools but as you say you can do that stuff better in a dedicated 3D program.
                                                  Now I compose on occasion 3d models into site photographs and this is an important communications to make to the client and many times to the public at large.
                                                  I think if you get over the idea that Photoshop's 3D space and tools is supposed to compete with the 3D programs and see it from a different perspective then you probably will see though they do not have it correct right now they are heading in the right direction.
                                                  And I hope the team sees what i a saying as well.
                                                  I do not say there should not be more creative tools in the 3D feature but it does not have to be as extensive as a 3D program, which it is not.
                                                  • 23. Re: CS4 3D, an inauspicious beginning
                                                    Welles - one thing to try: go ahead and create UV coordinates for the model, then save and open in Photoshop. Photoshop might be spending all of it's time on UV parameterization.
                                                    • 24. Re: CS4 3D, an inauspicious beginning
                                                      jpro2007 Community Member
                                                      I can get the model open okay on my system in CS4. (8 core xeon 2.8, 6.5 GB RAM. 10.5.4)
                                                      I let it sit a little while, but not terribly long; just while I read a couple of posts here.
                                                      I made UVs in a different app, it opened much more quickly. I don't have Vue to test with -- my other app may have done something else to clean the file up when it exported it with UVs.
                                                      • 25. Re: CS4 3D, an inauspicious beginning
                                                        Hi Chris,
                                                        You've identified the problem with that file. I ran it through UV Mapper and saved the file as a single group with planar mapping and sure enough it opened up in 40 seconds.
                                                        Hi jean p.
                                                        Thanks for trying that model. Vue 6 Infinite had no problem opening it. Carrara 6 Pro choked on it but eventually opened it but trying to create a UV Map was taking an eternity so I went with UV Mapper. I think I may have to get the pro version.
                                                        • 26. Re: CS4 3D, an inauspicious beginning
                                                          Welles, I wouldn't assume that creating UVs in UVMapper proves the UV generation is the issue.
                                                          I take problematic OBJ files through UV mapper all the time to clean them up, because UVMapper writes very good OBJs when other apps make messes of them. My test was with Strata 5.5, which also writes very good OBJ files. I can't rule out the possibility that Strata cleaned the file up, and I know from experience that UVMapper writes much better OBJ files than many 3D apps.
                                                          the only way to prove that the UV generation is the issue is to generate your UVs in the same app that you started with... can Vue create UVs?
                                                          For all that, I still think it is a good theory, I just don't think it is proved by bringing UVMapper into the picture.
                                                          You could do a more valid comparison by saving the file back out of UVMapper once with UVs and once without. Then compare Photoshop's load time with those 2 files.
                                                          • 27. Re: CS4 3D, an inauspicious beginning
                                                            jean p
                                                            Hmmm, you may well be right. I made the original in XenoDream, not Vue. I merely imported it into Vue to use in a scene. I can't attest to the quality of OBJ files exported from XenoDream. I've just begun to learn that software (there's no Mac version). The only experiential prelude to my post here was that the day before I received CS4 I had used that model in a 3D layer in CS3 and it opened up in 15 seconds or so. The next day with PS CS4 it was 5.5 minutes and it seemed, the first time I tried to import it into PS CS4 to be much longer than that.
                                                            • 28. Re: CS4 3D, an inauspicious beginning
                                                              skrocki Community Member
                                                              Open GL limitations and CS4:
                                                              http://www.adobe.com/go/kb404898
                                                              • 29. Re: CS4 3D, an inauspicious beginning
        I just got photoshop CS4 upgrade but when I go to load it freezes on "checking system profile" under Adobe Photoshop CS4 installer initializing - it goes about 90% of the way then freezes. I have shut down everything except the finder and have restarted my machine. I also tried copying the disk to my desktop. Nothing has worked for me so far. I have a PowerMac G5 Quad with 4 GB of memory running system 10.4.11 with ample disk space. Any suggestion?. I will try to phone Adobe tech support on Monday.
        Fred Perrine
        • 30. Re: CS4 3D, an inauspicious beginning
        Neil_Keller Community Member
        fred,
        Before attempting the upgrade, did you repair permissions, do disk repairs, and run DiskWarrior? Also, I don't know what you consider "ample disk space".
        Neil
        • 31. Re: CS4 3D, an inauspicious beginning
        My guess is that your System is in need of maintenance.
        Try running DiskWarrior and doing an Archive & Install of OSX from the original CD followed by running the latest Combo Updater.
        You could also try doing the CS4 installation from a new User Account.
        • 32. Re: CS4 3D, an inauspicious beginning
        Ramón G Castañeda Community Member
        "Ample" as in well over 100GB of available unfragmented disk space?
        • 33. Re: CS4 3D, an inauspicious beginning
        I'm in the same boat. I've run DiskWarrior, tried from a new user account, a safe boot, a root install, and I did an archive and install of OSX followed by adding the latest updater. I also copied the install to the desktop.
        It hangs at 90%.
        Adobe, unfortunately, has no definitive answer to the problem.
        The software did install on an older Mac. This is a newer Mac, some 300 gigs of empty drive space, 4 gigs of RAM.
        Does anyone have any ideas?
        • 34. Re: CS4 3D, an inauspicious beginning
        Community Member
        I should add, that I'm trying an install of Design Premium CS4.
        • 35. Re: CS4 3D, an inauspicious beginning
        Glorria you should be not having any problems.
        I would say you want to reformat your disk first backing up all the data and reinstall your system then CS 4 and what ever else you need.
        • 36. Re: CS4 3D, an inauspicious beginning
        Allen Wicks Community Member
        Ouch. Sounds like a reason to stay with CS3. :)
        • 37. Re: CS4 3D, an inauspicious beginning
        Not CS 4's problem Allen something is wrong with Gloria's system or she has done something like jump ahead of herself either because of impatience or lack of knowledge. Like most of us have done from time to time.
        For instance I have to boots on two different drives one updates to OS 10.5.6 just fine the other seems stuck on will not update.I think I know what happened but I do not know the way to correct it. If I were able to work with the unix console I could probably find the problem and correct it but I have little knowledge of that method so I have to do an archival reinstall.
        In this case CS 4 is installed on the OS 10.5.6 system and works great. But I have CS 3 on the 10.5.5 and that version of the Design Premium has always had some but not a lot of difficulties, well at least more then CS 4 which has some problems with some a couple of motion graphic applications.
        So this may be an accidental occurrence hat has taken place on Gloria's system and she may have no choice. And she may in the ned be better off!
        BTW Gloria this is the wrong thread to post this problem in you should start a new thread you might get some constructive suggestions about fixing your problem.
        • 38. Re: CS4 3D, an inauspicious beginning
        Community Member
        "I think I know what happened but I do not know the way to correct it." - you download the full upgrade .dmg package from Apple 10.5.6. Upgrades downloaded using Software Update are not as reliable, they need to fit certain criteria before launching. Back up before you do it.
        • 39. Re: CS4 3D, an inauspicious beginning
        Well it is done and I really do not need it at the moment and if I do I can do an archival reinstall on that disk which only has the OS and the Applications on that partition.
        But you are correct I download from the system updater. Now it will not let me erase the download files since I cannot locate them. Which is kind of stupid on Apples part!
        Anyone know where the download is stored?
        1 2 Previous Next
