This content has been marked as final.
Show 4 replies
1. Re: shortcut keyboard command for "consolidate all"
c.pfaffenbichler Feb 2, 2009 10:53 PM (in response to marc@marcyankus.com)Have You tried assigning a Shortcut under
Edit Keyboard Shortcuts Window Arrange Consolidate All to Tabs? -
2. Re: shortcut keyboard command for "consolidate all"
marc@marcyankus.com Feb 3, 2009 7:15 AM (in response to marc@marcyankus.com)That's not what I'm trying to do. My images are in tabs already. There is a square icon in the bar just below the menu bar. It has a rectangle and two squares in the icon. If you click on this square icon, the first icon that is displayed, which is a single grey square, will added gray around your tabs images and you will not be able to see any other application behind it.
This is similar to selecting "Application frame" which is also under Window but slightly different.
I never used Application Frame before so I guess that might be my solution since you can create a keyboard shortcut for that.
Marc -
3. Re: shortcut keyboard command for "consolidate all"
Omke Oudeman Feb 3, 2009 7:41 AM (in response to marc@marcyankus.com)That is what the Application frame is made for. You can drag it al over your screen, snap it between the panels and you end up with one big window with tools, panel, application bar and you can also choose a custom background color for the application frame. click on the frame background and with right click you can customize it to your wishes. Save it as a workspace and you will soon get used to it :-) -
4. Re: shortcut keyboard command for "consolidate all"
marc@marcyankus.com Feb 3, 2009 10:36 AM (in response to marc@marcyankus.com)Thanks Omke. I'm using it now since yesterday and like it alot!
It would be a nice feature that when your in Application Frame is one could also take the hand tool and move the image around while in the tab mode.
Marc
