4 Replies Latest reply on Mar 23, 2009 4:18 AM by MacWright
    add "unite" function to multiple paths
    MacWright Level 1
      to create a single clipping path from multiple paths it would be nice to add the "unite" AI pathfinder function to merge 2 overlapping paths
      select 2 paths> choose "unite" from drop down ?
        • 1. Re: add "unite" function to multiple paths
          Level 1
          its been asked for and ignored several times.
          don't go getting carried away with the idea that just because there's a feature set in PS that your expected to use it in an intensive manner.
          either they won't or they can't. Take your pick.
          Scissors are apparently a no-go as well... just in case someone starts running with the idea.
          But there is a new interface, and 3d as well... so expect that to be 1/2 baked for the rest of it's life as well.
          • 2. Re: add "unite" function to multiple paths
            MacWright Level 1
            running with scissors : )
            fortunately transferring paths back and forth from AI to PS is easy enough, so the pathfinder tools are still an option.
            • 3. Re: add "unite" function to multiple paths
              Level 1
              As far as I'm aware the feature you are asking for already exists. Make sure both your overlapping paths are part of the same workpath (if they are not, copy and paste them so that they are). Select them both with the black path selection tool. Then in the options bar there is now an option called "combine".
              This was option wasn't always available, I think was introduced a few versions ago. There are no more sophisticated pathfinder options than this. As you said its so easy to copy and paste from Illustrator.
              • 4. Re: add "unite" function to multiple paths
                MacWright Level 1
                Hi Mark,
                The Unite function is different from the Combine function in that it calculates one path outline from the the 2 shapes and removes the overlapping paths.
                j
