35 Replies Latest reply on Sep 29, 2006 5:30 PM by Newsgroup_User
    Hittest and overlapping
    _eidolon
      Hi
      Im making a lemmings type game for flash
      Sometimes there are 2 or more MC's that are over lapping at a certain point, all of which are in a hitTest array example code attached. When the hittest is run i want to pass a variable to ONLY the top MC, any thoughts on how todo this?
      Justin
        • 1. Re: Hittest and overlapping
          Level 7
          "_eidolon" <webforumsuser@macromedia.com> wrote in message
          news:efk3fu$r9b$1@forums.macromedia.com...
          > Hi
          > point,
          > hittest is
          > todo
          > this?
          > Justin
          > for (var i in charArray) {
          > if (_root[charArray ].hitTest(_xmouse, _ymouse, true)) {
          > _root[charArray
          ].currentAction = selectedAction;
          Just an idea... but you could try something like:
          I assume charArray is an Array of MovieClip refs?
          NOTE ---- NOT TESTED
          var hit_mcs:Array = new Array();
          for (var i:Number = 0; i < charArray.length; i++) {
          if (charArray .hitTest(_xmouse, _ymouse, true)) {
          hit_mcs.push({mc:charArray
          , depth:charArray .getDepth()});
          function compareDepths(a:Object, b:Object) {
          var d1:Number = a.depth;
          var d2:Number = b.depth;
          if (d1 > d2) {
          return 1;
          } else if (d1 < d2) {
          return -1;
          } else {
          return 0;
          hit_mcs.sort(compareDepths);
          then hit_mcs[0].mc would be a ref to the top mc...
          • 2. Re: Hittest and overlapping
            Level 7
            > Hi
            > point,
            > hittest is
            > todo
            > this?
            > Justin
            > _root[charArray
            if (d1 > d2) {
            return 1;
            return -1;
            } else {
            return 0;
            • 3. Re: Hittest and overlapping
              there are quite a few ways to do that. because you're probably going to be running many hitTests, the best might be to reorder the elements of charArray() so the movieclip with the smallest depth is element zero, the next smallest is element one,..., the one with the greatest depth is the last.
              you could then use your current hitTest code and stop (break or return) with the first positive hitTest because that movieclip will have the greatest depth.
              • 4. Re: Hittest and overlapping
                Level 7
                > Hi
                > point,
                > hittest is
                > todo
                > this?
                > Justin
                > _root[charArray
                if (d1 > d2) {
                return 1;
                return -1;
                } else {
                return 0;
                • 5. Re: Hittest and overlapping
                  Level 7
                  > Hi
                  > point,
                  > hittest is
                  > todo
                  > this?
                  > Justin
                  > _root[charArray
                  if (d1 > d2) {
                  return 1;
                  return -1;
                  } else {
                  return 0;
                  • 6. Re: Hittest and overlapping
                    Level 7
                    > Hi
                    > point,
                    > hittest is
                    > todo
                    > this?
                    > Justin
                    > _root[charArray
                    if (d1 > d2) {
                    return 1;
                    return -1;
                    } else {
                    return 0;
                    • 7. Re: Hittest and overlapping
                      Level 7
                      > Hi
                      > point,
                      > hittest is
                      > todo
                      > this?
                      > Justin
                      > _root[charArray
                      if (d1 > d2) {
                      return 1;
                      return -1;
                      } else {
                      return 0;
                      • 8. Re: Hittest and overlapping
                        Level 7
                        > Hi
                        > point,
                        > hittest is
                        > todo
                        > this?
                        > Justin
                        > _root[charArray
                        if (d1 > d2) {
                        return 1;
                        return -1;
                        } else {
                        return 0;
                        • 9. Re: Hittest and overlapping
                          Level 7
                          > Hi
                          > point,
                          > hittest is
                          > todo
                          > this?
                          > Justin
                          > _root[charArray
                          if (d1 > d2) {
                          return 1;
                          return -1;
                          } else {
                          return 0;
                          • 10. Re: Hittest and overlapping
                            Level 7
                            > Hi
                            > point,
                            > hittest is
                            > todo
                            > this?
                            > Justin
                            > _root[charArray
                            if (d1 > d2) {
                            return 1;
                            return -1;
                            } else {
                            return 0;
                            • 11. Re: Hittest and overlapping
                              Level 7
                              > Hi
                              > point,
                              > hittest is
                              > todo
                              > this?
                              > Justin
                              > _root[charArray
                              if (d1 > d2) {
                              return 1;
                              return -1;
                              } else {
                              return 0;
                              • 12. Re: Hittest and overlapping
                                sheesh, stop already.
                                • 13. Re: Hittest and overlapping
                                  Level 7
                                  > Hi
                                  > point,
                                  > hittest is
                                  > todo
                                  > this?
                                  > Justin
                                  > _root[charArray
                                  if (d1 > d2) {
                                  return 1;
                                  return -1;
                                  } else {
                                  return 0;
                                  • 14. Re: Hittest and overlapping
                                    Level 7
                                    > Hi
                                    > point,
                                    > hittest is
                                    > todo
                                    > this?
                                    > Justin
                                    > _root[charArray
                                    if (d1 > d2) {
                                    return 1;
                                    return -1;
                                    } else {
                                    return 0;
                                    • 15. Re: Hittest and overlapping
                                      Level 7
                                      > Hi
                                      > point,
                                      > hittest is
                                      > todo
                                      > this?
                                      > Justin
                                      > _root[charArray
                                      if (d1 > d2) {
                                      return 1;
                                      return -1;
                                      } else {
                                      return 0;
                                      • 16. Re: Hittest and overlapping
                                        Level 7
                                        > Hi
                                        > point,
                                        > hittest is
                                        > todo
                                        > this?
                                        > Justin
                                        > _root[charArray
                                        if (d1 > d2) {
                                        return 1;
                                        return -1;
                                        } else {
                                        return 0;
                                        • 17. Re: Hittest and overlapping
                                          Level 7
                                          > Hi
                                          > point,
                                          > hittest is
                                          > todo
                                          > this?
                                          > Justin
                                          > _root[charArray
                                          if (d1 > d2) {
                                          return 1;
                                          return -1;
                                          } else {
                                          return 0;
                                          • 18. Re: Hittest and overlapping
                                            Level 7
                                            > Hi
                                            > point,
                                            > hittest is
                                            > todo
                                            > this?
                                            > Justin
                                            > _root[charArray
                                            if (d1 > d2) {
                                            return 1;
                                            return -1;
                                            } else {
                                            return 0;
                                            • 19. Re: Hittest and overlapping
                                              Level 7
                                              > Hi
                                              > point,
                                              > hittest is
                                              > todo
                                              > this?
                                              > Justin
                                              > _root[charArray
                                              if (d1 > d2) {
                                              return 1;
                                              return -1;
                                              } else {
                                              return 0;
                                              • 20. Re: Hittest and overlapping
                                                Level 7
                                                > Hi
                                                > point,
                                                > hittest is
                                                > todo
                                                > this?
                                                > Justin
                                                > _root[charArray
                                                if (d1 > d2) {
                                                return 1;
                                                return -1;
                                                } else {
                                                return 0;
                                                • 21. Re: Hittest and overlapping
                                                  Level 7
                                                  > Hi
                                                  > point,
                                                  > hittest is
                                                  > todo
                                                  > this?
                                                  > Justin
                                                  > _root[charArray
                                                  if (d1 > d2) {
                                                  return 1;
                                                  return -1;
                                                  } else {
                                                  return 0;
                                                  • 22. Re: Hittest and overlapping
                                                    Level 7
                                                    > Hi
                                                    > point,
                                                    > hittest is
                                                    > todo
                                                    > this?
                                                    > Justin
                                                    > _root[charArray
                                                    if (d1 > d2) {
                                                    return 1;
                                                    return -1;
                                                    } else {
                                                    return 0;
                                                    • 23. Re: Hittest and overlapping
                                                      Level 7
                                                      > Hi
                                                      > point,
                                                      > hittest is
                                                      > todo
                                                      > this?
                                                      > Justin
                                                      > _root[charArray
                                                      if (d1 > d2) {
                                                      return 1;
                                                      return -1;
                                                      } else {
                                                      return 0;
                                                      • 24. Re: Hittest and overlapping
                                                        Level 7
                                                        > Hi
                                                        > point,
                                                        > hittest is
                                                        > todo
                                                        > this?
                                                        > Justin
                                                        > _root[charArray
                                                        if (d1 > d2) {
                                                        return 1;
                                                        return -1;
                                                        } else {
                                                        return 0;
                                                        • 25. Re: Hittest and overlapping
                                                          Level 7
                                                          > Hi
                                                          > point,
                                                          > hittest is
                                                          > todo
                                                          > this?
                                                          > Justin
                                                          > _root[charArray
                                                          if (d1 > d2) {
                                                          return 1;
                                                          return -1;
                                                          } else {
                                                          return 0;
                                                          • 26. Re: Hittest and overlapping
                                                            Level 7
                                                            > Hi
                                                            > point,
                                                            > hittest is
                                                            > todo
                                                            > this?
                                                            > Justin
                                                            > _root[charArray
                                                            if (d1 > d2) {
                                                            return 1;
                                                            return -1;
                                                            } else {
                                                            return 0;
                                                            • 27. Re: Hittest and overlapping
                                                              Level 7
                                                              > Hi
                                                              > point,
                                                              > hittest is
                                                              > todo
                                                              > this?
                                                              > Justin
                                                              > _root[charArray
                                                              if (d1 > d2) {
                                                              return 1;
                                                              return -1;
                                                              } else {
                                                              return 0;
                                                              • 28. Re: Hittest and overlapping
        Level 7
        > Hi
        > point,
        > hittest is
        > todo
        > this?
        > Justin
        > _root[charArray
        if (d1 > d2) {
        return 1;
        return -1;
        } else {
        return 0;
        • 29. Re: Hittest and overlapping
        Level 7
        > Hi
        > point,
        > hittest is
        > todo
        > this?
        > Justin
        > _root[charArray
        if (d1 > d2) {
        return 1;
        return -1;
        } else {
        return 0;
        • 30. Re: Hittest and overlapping
        Level 7
        > Hi
        > point,
        > hittest is
        > todo
        > this?
        > Justin
        > _root[charArray
        if (d1 > d2) {
        return 1;
        return -1;
        } else {
        return 0;
        • 31. Re: Hittest and overlapping
        Level 7
        > Hi
        > point,
        > hittest is
        > todo
        > this?
        > Justin
        > _root[charArray
        if (d1 > d2) {
        return 1;
        return -1;
        } else {
        return 0;
        • 32. Re: Hittest and overlapping
        Level 7
        > Hi
        > point,
        > hittest is
        > todo
        > this?
        > Justin
        > _root[charArray
        if (d1 > d2) {
        return 1;
        return -1;
        } else {
        return 0;
        • 33. Re: Hittest and overlapping
        Level 7
        > Hi
        > point,
        > hittest is
        > todo
        > this?
        > Justin
        > _root[charArray
        if (d1 > d2) {
        return 1;
        return -1;
        } else {
        return 0;
        • 34. Re: Hittest and overlapping
        Level 7
        > Hi
        > point,
        > hittest is
        > todo
        > this?
        > Justin
        > _root[charArray
        if (d1 > d2) {
        return 1;
        return -1;
        } else {
        return 0;
        • 35. Re: Hittest and overlapping
        Level 7
        > Hi
        > point,
        > hittest is
        > todo
        > this?
        > Justin
        > _root[charArray
        if (d1 > d2) {
        return 1;
        return -1;
        } else {
        return 0;
