• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Conditional Tag Stylesheet Reference?
New Here ,
Nov 20, 2008 Nov 20, 2008
I have a branded version of help and a generic version of help.
I originally set this up using two different templates, each with their own separate stylesheet.
But this is extra work when I output layouts. I have to switch all topics from one template to another. (Ideally you should be able to select a template in the layout options, no?)
I'd like to use one template and use conditional tags to show the appropriate stylesheet. Is this possible?
Or is there some other way to accomplish the same thing?
Thanks for your help.
Views
563
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Depending on your version of RH and quite how the branding is implemented, sounds like Variables could help. In one version a value could be GenericName and in another BrandX.
Votes
Translate
Translate
Report
Report
New Here ,
I'm using RH 7.
I'm using variables and tags. That works great.
What I'm trying to do is generate 2 layouts from the same topics that use different stylesheets, w/o having to switch templates.
Votes
Translate
Translate
Report
Report
Community Expert ,
Is the change just the CSS stylesheet or does the template have to change as well?
Votes
Translate
Translate
Report
Report
New Here ,
I'd just like to change the reference to another stylesheet, for example from styleBrand.css to styleGeneric.css.
I'm only using the template so I can have separate stylesheets. (I'm using tags to show different content in the headers and footers.)
Thanks again.
Votes
Translate
Translate
Report
Report
Community Expert ,
So assuming all topics have one CSS, in the topic list select all the topics and right click. In Properties select the other style sheet and generate. Then revert back.
Votes
Translate
Translate
Report
Report
New Here ,
That is what I'm doing now.
I'm asking if there is a way to do it programatically/automatically so I can batch generate both layouts without manually having to swap out templates or stylesheets.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
"What I'm trying to do is generate 2 layouts from the same topics that use different stylesheets, w/o having to switch templates."
What I suggested does allow you to switch CSS without switching template. Sorry misunderstood you.
Votes
Translate
Translate
Report
Report
LEGEND ,
I'm afraid not without manually assigning the template.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
