This content has been marked as final.
Show 12 replies
1. Re: How do I insert a flyer made in Photoshop into the body of an email...
Buko. Oct 22, 2008 5:36 PM (in response to (BJ_Cephas))Your problem is AOL -
2. Re: How do I insert a flyer made in Photoshop into the body of an email...
Buko. Oct 22, 2008 5:37 PM (in response to (BJ_Cephas))You need to get real ISP -
3. Re: How do I insert a flyer made in Photoshop into the body of an email...
Bart Cross Oct 22, 2008 5:51 PM (in response to (BJ_Cephas))I believe the problem is that AOL uses proprietary image handling. I think it has an .art extension, not so sure about it, haven't touched AOL in a decade. -
4. Re: How do I insert a flyer made in Photoshop into the body of an email...
John Joslin Oct 22, 2008 11:55 PM (in response to (BJ_Cephas))The only time I touch AOL is to clean it off other users' computers! -
5. Re: How do I insert a flyer made in Photoshop into the body of an email...
(BJ_Cephas) Oct 23, 2008 3:36 AM (in response to (BJ_Cephas))Ok I see AOL is the 'BIG Monster' here. However my question minus the AOL part, am I not doing something in the final saving process that would give me a better result? Many people I email to are on AOL and I recieve emails all the time with embedded flyers and they read fine.
I just need to know if there is something else I should be doing in the final process after building my flyer in Photoshop so that it translates well for all browsers.
Thank you all, BJ -
6. Re: How do I insert a flyer made in Photoshop into the body of an email...
Jim or Marion Jordan Oct 23, 2008 4:45 AM (in response to (BJ_Cephas))What happens if your recipients' email clients do not display images by default? Will your message still get across?
http://www.emaillabs.com/tools/email-marketing-statistics.html#blockedimages
Hopefully, you have no more than 100 recipients to your email marketing as AOL imposes a limit.
The comparison between messages you send and those you have received should be clearly made. Were those messages that you received sent from AOL? Were they sent with the same AOL mail client? Do they use images attached to the message or called from a web server? -
7. Re: How do I insert a flyer made in Photoshop into the body of an email...
(BJ_Cephas) Oct 23, 2008 6:38 AM (in response to (BJ_Cephas))Hi Jim,
Were those messages that you received sent from AOL? No
Were they sent with the same AOL mail client? No
Do they use images attached to the message or called from a web server? Now that I think about it I am betting that they were sent from their server.
Which leads me to ask how that is done?
It just seems that this process can't be all that hard and I am just missing some step.
Thank you for your reply,
BJ -
8. Re: How do I insert a flyer made in Photoshop into the body of an email...
Jim or Marion Jordan Oct 23, 2008 7:01 AM (in response to (BJ_Cephas))Most HTML email marketing is done by calling images hosted on a web server. This makes delivery more efficient because the sender does not need to send image data with every message. Images are only called from the web server if the user opens the email.
Of course, if you are not using a web server, then you are stuck with packing the image files in your email.
It may be good to check out the web design forum (and GoLive/Dreamweaver forums) here as this HTML mail topic comes up often. -
9. Re: How do I insert a flyer made in Photoshop into the body of an email...
(BJ_Cephas) Oct 23, 2008 7:38 AM (in response to (BJ_Cephas))Thank you Jim finally an answer that makes sense. I will check our webserver capabilities and go to the forum at GoLive/Dreamweaver. Thank you, BJ -
10. Re: How do I insert a flyer made in Photoshop into the body of an email...
Michael D Sullivan Dec 26, 2008 7:54 PM (in response to (BJ_Cephas))If you include external images in an email, many people won't see them, since many email programs now (Huzzah!) turn off the ability to display external images by default. The user will need to click on something or add the sender to a safe senders list to see the images automatically. This is a good thing, as automatic external image display was misused for the spreading of viruses and trojans. -
11. Re: How do I insert a flyer made in Photoshop into the body of an email...
dave milbut Dec 26, 2008 8:45 PM (in response to (BJ_Cephas))>This is a good thing, as automatic external image display was misused for the spreading of viruses and trojans.
not to mention marketers with single pixel tracking cookies used to verify they've found a live address... -
12. Re: How do I insert a flyer made in Photoshop into the body of an email...
Michael D Sullivan Dec 26, 2008 9:06 PM (in response to (BJ_Cephas))Yep. I don't think MS had any problems with "web bugs" or "web beacons" such as those, but even Microsoft made the default not to display external images, after the baddies started loading .exe files as though they were images or audio files.
