1 Reply Latest reply on Nov 28, 2008 10:13 AM by John Hall
    parallel effect on different targets having strange behaviour
    pulse00
      Hi all,
      i'm having troubles getting a transition to work that uses a parallel effect to move one component up, and resize the other one simultaniously.
      Basically, i use 2 viewstates. In the first state, only one component is visible, in the other state both are visible. The transition should move the upper component out/in and resize the other one at the same time.
      Here's a testcase that illustrates my problem:
      www.dubture.net/test.swf (source view enabled)
      During the transition, the upper button gets resized, not moved. As soon as i comment out the resize effect, it moves up correctly (but the lower button doesn't resize apparently).
      Anyone knows why this is happening ?
      thanks !
