This content has been marked as final.
Show 7 replies
1. Re: Faint image border when saving JPG/PNG
Geoff Jay Feb 1, 2009 4:57 PM (in response to ac361)Are you selecting the background then filling it with a colour? If so is the anti-alias turned on? This could be causing the border you describe.
Geoff. -
2. Re: Faint image border when saving JPG/PNG
ac361 Feb 1, 2009 5:06 PM (in response to ac361)Thanks, Geoff. Not quite. I'm using the rectangle tool, creating a rectangle, then filling it with a color. Then I cut out a portion of it using the select tool, resize that in a new window and save it.
Maybe there's a better way to do this: I need to create a rectangle with some styled text on top, save it and have it blend into a solid color of the same as the rectangle on the web page. -
3. Re: Faint image border when saving JPG/PNG
Geoff Jay Feb 1, 2009 5:47 PM (in response to ac361)When you use the Select tool is the feather value set to zero? If not this could be giving you a soft edge if the background layer is showing through.
Perhaps a better method would be to create a new file with the pixel dimensions that you need then filling it with the required colour then putting your text on top. Save this as a psd file in case you need to make changes in the future, then Save for Web as a jpg.
Geoff. -
4. Re: Faint image border when saving JPG/PNG
Mylenium Feb 2, 2009 12:09 AM (in response to ac361)Na, this is unrelated to the select or crop tools and has always been this way. Any floating layer will be resized with sampling, meaning that its edges will be antialiased. This is not immediately apparent in PS when cropping the layers to that size, but causes the problem when saving for web. Hence the logical workflow must be to fill those layers after the transform, use Solid Fill adjustment layers or, if possible, even merge down such layers to the background.
Mylenium -
5. Re: Faint image border when saving JPG/PNG
(Phos±four_dots) Feb 2, 2009 3:30 AM (in response to ac361)Why not create your styled text on a transparent layer, then save as a PNG24?
No filled rectangle to deal withjust your text and fully alpha-channeled transparency. It'll work over any background color you choose for your webpage. -
6. Re: Faint image border when saving JPG/PNG
Yammer Feb 2, 2009 3:33 AM (in response to ac361)One thing I've noticed, which I've never seen written, is that when you resize a layer it anti-aliases the edge. If I want to resize a finished image, I flatten it first, then resize. For some reason a flattened image keeps a sharp edge, whereas one in layers does not. -
7. Re: Faint image border when saving JPG/PNG
Chris Cox Feb 3, 2009 6:16 PM (in response to ac361)Because the layer has data outside the layer -- 100% transparent data.
There's really no good way to avoid that.
