16 Replies Latest reply on Nov 5, 2011 3:10 PM by Delmar Penner
    CS4 Photomerge doesn't work
    PanosFX Level 2
      Photomerge doesn't work for me when I am trying to run it from Bridge or from Photoshop. Photoshop stitches the images but when the process is done the document closes, resulting in no image.
      The same issue has been discussed in this thread, but no solution was provided:
      http://www.adobeforums.com/webx?128@@.59b830ed
      Purging the selection / folder cache in Bridge prior to merging doesn't help.
      Resetting the PS preferences solves the problem but only temporarily. The issue appears again when you try to make up another panorama.
      At first I tried it on 4 RAW shots. Then on another set of 6 RAW shots. No luck.
      SCRATCH DISK: 1 Tb
      SYSTEM SPECS:
      Operating System: Windows Vista 32-bit
      Version: 6.0 Service Pack 1
      System architecture: Intel CPU Family:6, Model:10, Stepping:4 with MMX, SSE Integer, SSE FP, SSE2
      Physical processor count: 4
      Logical processor count: 8
      Processor speed: 2666 MHz
      Video Card Vendor: NVIDIA Corporation
      Video Card Renderer: GeForce GTX 260/PCI/SSE2
      Built-in memory: 3060 MB
      Free memory: 1161 MB
      Memory available to Photoshop: 1589 MB
      Memory used by Photoshop: 70 %
      Thank you
      Panos Efstathiadis
      www.PanosFX.com
        • 1. Re: CS4 Photomerge doesn't work
          ssprengel Adobe Community Professional & MVP
          Here are some more things I can think of to try experimenting with in case you find a combination that works. The main idea is that there is a resource issue that Photoshop is not gracefully handling.
          Does it even work if you stitch a couple tiny images, and then what is the number or size of images where it starts to fail consistently, and then can you vary things related to resources where it starts to work with a larger set of images that used to fail, before?
          Try changing the amount of memory available to Photoshop in Preferences, where smaller seems like the direction you can go from what you've posted.
          Try changing your scratch disk to another drive, perhaps even the program drive and/or the system-boot drive. It's unlikely it's running out of 1TB but maybe something about that particular HD is causing a problem.
          Watch the amount of memory used by Photoshop in TaskManager and see if it fails when the amount of memory used passes a certain threshhold. Select both Commit Size and Working Set as types of memory to track in the process view, and also watch the total memory used by the system in the Performance tab.
          If there is a BIOS setting when you boot your computer for how much memory your video card uses try changing it.
          The memory size being a multple of 3GB seems like an uncommon amount. Maybe take one memory chip out so it is a multiple of 2GB. Only do this if you are comfortable mucking around with your hardware and use proper static-reduction techniques, etc.
          Try reducing and expanding the number of history states Photoshop keeps track of using Preferences.
          You don't say anything about OpenGL settings, so I assume your card doesn't support it? If it does, try turning it off or try turning it on if it's off but can be used.
          • 2. Re: CS4 Photomerge doesn't work
            Level 1
            Sorry to butt in here,
            I don't know the answer but some other guy was on here awhile & ago posted
            same problem with RAW files (only)
            He said changing them to other formats worked, like tiff or jpg.
            So it may not be related to your comp putzing out but to the new photomerge
            unable to handle RAW.
            off topic:
            CS4 (sorry) sounds horrid
            it is one update I will skip
            I have found open GL to really suck for gaming applications and too much of
            CS4 seems dependent upon it
            too bad there is no Direct x choice on CS4 (even ancient 3d vid games have
            that option)
            have never had any issues with programs running Direct x
            maybe Mac cannot use it?
            I cannot afford to upgrade all my hardware this year, am reluctant to change
            to Vista for obvious reasons, and PS is too important to my work to risk
            messing up with a poorly designed upgrade that messes up functions that
            previously worked well in CS3.
            I love CS3 and will stick with it until this comp dies and I have to replace
            it.
            Does anyone know if the CS3 ACR works with newer cameras if you input jpgs
            not RAW formats?
            I prefer to upgrade the camera before replacing the comp and PS version.
            Cannot afford all 3 at once.
            • 3. Re: CS4 Photomerge doesn't work
              Hudechrome-sd9sPI Level 2
              If ACR doesn't show your camera, you need to convert to DNG first.
              • 4. Re: CS4 Photomerge doesn't work
                PanosFX Level 2
                Thank you for your replies.
                Steve: I lowered the amount of RAM used by Photoshop from 70% to 65% and it worked. My video card is among the latest NVidia cards. Therefore I don't think that the card is the problem.
                I even tried to photomerge 4 RAW images which I opened at a smaller resolution (@ 2.8 Mpx). Photomerge would not produce any results even in this case where the resources should not be a problem.
                I still cannot understand this peculiar behavior. I have PS CS4 for five months and Photomerge used to work fine (with the same preferences and PS & Bridge the only applications running).
                Anyway, I'm glad it's fixed even with this small compromise.
                Panos
                • 5. Re: CS4 Photomerge doesn't work
                  Since the amount of RAM is a percentage, Photoshop's allocation depends on how much is available at the time you start up Photoshop, so the fact it works on one day doesn't mean it'll work the next, so further tweaks in the Photoshop allocation could be necessary, but at least you know what to try.
                  I would guess that the PhotoMerge process is aborting due to a memory issue but it is deep enough that no error message is generated. This is surely a bug, and allocating even less memory to Photoshop may change when Photoshop is swapping things out to its scratch file sooner, allowing it to have more memory for itself, during the PhotoMerge.
                  It could also be something related to OpenGL being used for image rendering and the display-driver having an issue that Photoshop can't really see.
                  The amount of RAM available is somewhat dependent on what applications have run before, not just what are currently running, so even if you only ever have PS and Br running, the available RAM could be different based on what applications have already run and closed, already, and maybe some OS component or driver has been updated sine it used to work and that component uses slightly more or less memory than it used to. And even if there is an identical amount of RAM available, memory is allocated in chunks that aren't freed up immediately, so, again, it could depend on what applications have been run since a reboot.
                  It seems to me that CS4 and ACR have been updated to 11.0.1 and 5.3 less than 5 months ago, and maybe that is what is different, now.
                  • 6. Re: CS4 Photomerge doesn't work
                    Level 1
                    jpeg to dng???
                    I was asking if CS4 ACR will still take jpg from the newer cameras even
                    though I know it will not do the RAW files
                    • 7. Re: CS4 Photomerge doesn't work
                      John Joslin Level 6
                      It should, try it.
                      The data that is needed to interpret a camera-specific raw file should not be needed for a JPEG.
                      • 8. Re: CS4 Photomerge doesn't work
                        Level 1
                        > It should, try it.
                        I don't own the camera (YET)
                        would have to try it with a rental
                        • 9. Re: CS4 Photomerge doesn't work
                          John Joslin Level 6
                          You could take a card in and try a shot taken in the shop.
                          • 10. Re: CS4 Photomerge doesn't work
                            And while you are at it, load some images as RAW and see for yourself.
                            I never use jpeg.
                            • 11. Re: CS4 Photomerge doesn't work
                              weedinner
                              This IS weird.
                              Photomerge does not work on my Mac 2x3 ghz dual core Intel Xeon with 7 gb of ram
                              Photomerge does work on my MacBook Pro with 4 Gig of RAm.
                              Same software, works from Lightroom, works with raw files.
                              Also on my desktop machine photoshop only recognises that I have 3072 mb available. Its the same with the laptop, yet I have 7 gb in the desktop.
                              • 12. Re: CS4 Photomerge doesn't work
                                IainOct1967
                                Hi, Have just tried to use photomerge in CS4 mac. Trying to merge 4 photos into a panorama, have tried both jpeg and tiff versions. It only seems to open one file then freezes. Have successfully done it in CS2 on my laptop. Any ideas? Thanks
                                • 13. Re: CS4 Photomerge doesn't work
                                  John Joslin Level 6
                                  I don't think the problem is platform specific but you should really ask in the Photoshop Mac forum.
                                  http://forums.adobe.com/community/photoshop/photoshop_macintosh
                                  • 14. Re: CS4 Photomerge doesn't work
                                    ionRane
                                    I also am having problems with photomerge crashing. Even using as few as 2 jpgs it crashes.
                                    Independant of running photomerge directly from PS, or from within Bridge, or from within Lightroom 2.5.
                                    Same behavior as previously reported: I see the selected files added as layers to a new file, and some processing happens, then suddenly everything closes, no evidence left behind.
                                    I have lowered the number of history states, and the amount of memory allocated to photoshop.
                                    I'm, running on XP.
                                    Open GL is not supported for the nVidia GeoForce Go 7400 card on my Vaio, so it is (sadly) disabled.
                                    I still have CS2 installed on my (same) system, and interestingly, photomerge works fine in CS2, although the results are less than stellar (in all due.. these images weren't properly shot for panorama stitching).  I'd like to see what photomerge CS4 can do..
                                    What is the fix for CS4?
                                    • 15. Re: CS4 Photomerge doesn't work
                                      ionRane Level 1
                                      What I have found to work is:
                                      1) File -> Scripts -> Load Files into Stack, with option "Attempt to Automatically Align Source Images" checked (or unchecked).
                                      2) Select -> All Layers in the file.
                                      3) Edit -> Auto-Align Layers. Choose desired options (ie auto, vignette removal, geometric distortion).
                                      4) If step 1 "auto align source images gave better results than step 2, then Ctrl-Z (or Edit -> undo auto-align layers).
                                           4b) optional. manually Free-Transform/Warp/Move individual layers to improve alignment.
                                      5) Edit -> Auto-Blend Layers. Choose Panorama option. Check [x] Seamless Tones and Colors.
                                      I do not know how closely Photomerge follows the Auto-Align, Auto-Blend, or Stack:Auto-Align routines
                                      ..but PS handles these routines (individually) fine.
                                      Photomerge seems to run through its routines fine and crash only at the last moment before revealing the outcome.
                                      I do not know a way to see what process causes the crash, or know why the file/process closes without saving any steps, or issuing an error message.
                                      • 16. Re: CS4 Photomerge doesn't work
                                        Delmar Penner
                                        Thanks! Now I finally found a work-around to an extremely annoying bug in PS CS4! Thank you!
