1 Reply Latest reply on Nov 24, 2008 9:56 AM by Zee Yang
    GET LAST INSERTED RECORD
    ssmacwilliams Level 1
      I am fairly new to flex. So please bear with me no this question.
      I would like to get MYSQL ID of the last record I inserted. MSQL has as function LAST_INSERT_ID() that is connection based and will return the last id of the last inserted record. My thought was in the function contained within the cfc to do 2 queries insert the record and return the last id directly after (see below). However, I don't know how I would read the results back into flex. I am unsure how to write the event handler. Thanks
      <cffunction name="insertUser" access="remote" returntype="query" >
      <cfargument name="SSN" required="false" type="string" hint="SSN"/>
      <cfargument name="FNAME" required="false" type="string" hint="FNAME"/>
      <cfargument name="LNAME" required="false" type="string" hint="LNAME"/>
      <cfargument name="CLIENTID" required="false" type="string" hint="NEW CLIENTID"/>
      <cfquery name="insUser" datasource="DBT">
      INSERT INTO CLIENT (SSN, FNAME, LNAME) VALUES (
      <cfqueryparam value="#ARGUMENTS.SSN#" cfsqltype="CF_SQL_VARCHAR" maxlength="12"/>,
      <cfqueryparam value="#ARGUMENTS.FNAME#" cfsqltype="CF_SQL_VARCHAR" maxlength="20"/>,
      <cfqueryparam value="#ARGUMENTS.LNAME#" cfsqltype="CF_SQL_VARCHAR" maxlength="30"/>)
      </cfquery>
      <cfquery name="qRead" datasource="DBT">
      SELECT last_insert_id() AS CLIENTID
      </cfquery>
      <cfreturn qRead >
      </cffunction>
        • 1. Re: GET LAST INSERTED RECORD
          Zee Yang
          I assume you have LCDS installed with CF and you are using the remote object service,
          <mx:RemoteObject
          id="myService"
          destination="ColdFusion"
          source="full.path.to.cfc"
          showBusyCursor="true">
          <mx:method name="insertUser" result="insertUser_result(event)" />
          </mx:RemoteObject>
          <mx:Scrpit>
          private function insertUser_result(event:ResultEvent) {
          trace(event.result);
          event.result will be the id of the newly inserted record.
          BTW, I would highly recommend you looking into the data management servcie. the SQLAssembler can spare you of the CF code for simple CRUDs like this.
