1 Reply Latest reply on Nov 26, 2008 6:16 AM by Captiv8r
    Image with Text Window Pop-Up
    Eva-KCI Level 1
      I have an image that I'd like the user to be able to click on certain spots to view additional information. Is it possible to do this without having to create topics separate from the topic that contains the image? Ideally, I'd like something like the text only pop-up to work on an image.
      Eva
        • 1. Re: Image with Text Window Pop-Up
          Hi Eva
          You could do one of a couple of things.
          1. Define Image Map regions and link them to #. This would simply cause the page to reload if the region were clicked by your user. With each region, you are able to specify Alternate text that appears in a Tool Tip when you hover the mouse over the area. This way would be simplest to achieve, but you may not like the fact the time the Tool Tip appears is a bit limited.
          2. If you hop over to this link: Click Here You are able to download my Tips and Tricks file. I believe I've documented how to make Image Map Regions work with Text-only Popups.
          Cheers... Rick
