1 Reply Latest reply on Nov 25, 2008 1:16 PM by webbo1968
    Delete first few seconds of Timeline
    4229Rental
      I am a new user of Captivate. I took a screen capture and the timing of the slide is 8 seconds. I would really like the slide to begin after the 2 second mark. Is it possible to delete the first two seconds of the slide, or at least lock the slide to begin after the 2 second mark?
      Thanks for your help!
        • 1. Re: Delete first few seconds of Timeline
          webbo1968 Level 1
          I think you are getting alittle confused with the timeline. Each individual slide has its own unique time line. If you wish something to appear after 2 seconds on say the first slide, set this in the properties for that item, eg graphic to not appear until after 2 seconds. Alternatively simply grab it on the time line and slide it left or right.
          You can change the length of each individual timeline as required, in the slide properties (double click the slide in left hand column)
          Hope this helps
          Webbo (UK)
