3 Replies Latest reply on Nov 25, 2008 7:13 AM by Peter Grainge
    Version 7 Help
    karengilbert Level 1
      We recently had Version 7 installed. We opened a version 5 project in Version 7 and generated the project. Several punctuation marks have not converted (i.e., instead of a "-" it states "endash", instead of "..." it states "If&idot"). Any idea of why certain punctuation isn't showing aftering generating the project?
      Also, we are unable to open the same project back in Version 5. Is there a way to reopen the project in version 5 after opening it in version 7?
        • 1. Re: Version 7 Help
          The problem you describe is covered in Using RH7 on my site. You need to apply two updates but you also need your project in X5 format to upgrade it again. You can fix the problem without but it is a lot more work.
          When you upgrade there is a warning that you will not be able to go back to the earlier version.
          • 2. Re: Version 7 Help
            Thanks, Peter. We have version 7.00.145, but we couldn't find a build (i.e., in version X5 we needed build 801). I checked your web site. Do we need to have version 7.0.1 and 7.0.2 installed? Is there a build for version 7? We understand that we cannot go back to version 5 and that we have to recreate the project in 5 to bring back into 7 once we have installed the two updates. Please advise, if you can, which updates we need. If you need further info, let me know. Thanks so much! (Our IT dept knows very little about RoboHelp and its installation - I rely heavily on this forum which provides so much information!)
            • 3. Re: Version 7 Help
              You need the two patches. Go to Help | Updates and RH should apply 7.0.1. Repeat that for 7.0.2. (RH may take you through both in the same session).
              Just look for these version numbers rather than any build numbers.
