0 Replies Latest reply on Nov 20, 2008 5:54 PM by slimbuddah
    Data Wizard Mamp Pro problem
    slimbuddah
      I've searched many forums and still haven't found an answer! I'm not sure if it's a Mamp Pro problem or a Flex one but I haven't yet been able to use the Data Wizard with Mamp Pro... Everything runs smoothly when using Mamp, but as soon as I try the same type of connection with Mamp Pro, Flex Data Wizard can't connect to the database anymore . Applications created with Mamp as a server run without any problems when switching to Mamp Pro, I can access the database directly with php within my script , if I create a new project, the configuration validates... it's only the Data Wizard which is a problem.
      I've read about similar situations in various forums but haven't found a solution yet?
      Thanks in advance!
      Patrick
