1 Reply Latest reply on Aug 29, 2008 6:13 PM by CaryD
    Edit Undo Disabled
      Dreamweaver will not allow me to select Undo from the Edit menu. It seems to be disabled as well as the Redo command. I cannot figure out what I have done! Please help.
        • 1. Re: Edit Undo Disabled
          CaryD Level 2
          You can check to see what your "Maximum number of history steps" is set to in the General category of Preferences, but "2" is the minimum possible with CS3.
          When you try to undo or redo, make sure you have the correct file selected in DW. For instance, you can't undo a change made to index.html if style.css is selected. That would simply undo the last change made to the style sheet if "undo" is available. It won't be available if no changes have been made to the file in the currently selected tab.
