2 Replies Latest reply on Dec 27, 2007 2:00 AM by (Andrzej_Bania)
    Problem with (seemingly) linked sequences across projects
      I use a common template (i.e. set of files and structures that I have set up once and am happy with) to kick off each new project
      I copy the main directory - paste it with a new name - rename the folder and project file - then start
      Recently (but not before - I don't think) I have had a serious problem where...
      ...adding new sequences into a project - seems to have an affect on the 'template' project (i.e. inserts blank sequences)...
      ...which, when deleted, also seem to create 'cascade deletes'
      This is causing tremendous grief :~(
      Any help/ideas appreciated !!!
        • 1. Re: Problem with (seemingly) linked sequences across projects
          Jim_Simon Level 8
          Here's my guess.
          The only way I can see for changes to affect a template is for you to make them. It's seems a Windows level impossibility for changes to be made to file X when you are working with file Y. So while you think you're working with file Y (the new project), you must actually be working in file X (the template).
          • 2. Re: Problem with (seemingly) linked sequences across projects
            Level 1
            Hi Jim,
            I agree that it seems impossible, but it has happened on 2 of our boxes - so I am uncertain of the cause :~(
            There is a secondary issue - whereby adding in a sequence to a project (copy of the original - but in a different folder with a different name etc) causes 'ghost sequences' in other projects
            Just so you know I am not completely nuts, I have worked in/around computers for 20 years - everything from programming to support to networking to sales to marketing etc etc etc...
            ...and I have never seen anything like it
            If I had to hazzard a guess, there is some kind of centralised 'asset management' (Photoshop Server ?) that is causing these links to exist and/or be supported/maintained
            If anyone else can add anything - then that would be great...
            ...for my part, if I manage to find a spare 20 minutes, I might video it happening (for sanity/posterity etc!)
