3 Replies Latest reply on Dec 27, 2007 4:03 PM by Steven L. Gotz
    Key Light
    dericktrotter
      Is it possible to get the plugin called KeyLight from After Effects CS3
      into Prem Pro CS3....
      Mike
        • 1. Re: Key Light
          Harm Millaard Level 7
          Don't think so. Try it and report back.
          • 2. Re: Key Light
            dericktrotter Level 1
            I have been trying as I did have success with some of the other plugins from <br />AF...... I did use the KeyLight in AF and exported it back  to PremPro  but <br />I got an error message saying that it did not have the KeyLight something or <br />other .....so whats the point of having it in AF if you cannot get back to <br />PremPro with the effect.<br /><br />Mike<br /><br /><br /><mikerawlinson@adobeforums.com> wrote in message <br />news:E132B7254CA6F98CA6900C027107FAA3@in.webcrossing.la2eafNXanI...<br />> Is it possible to get the plugin called KeyLight from After Effects CS3 <br />> into Prem Pro CS3....<br />><br />> Thanks<br />> Mike<br />>
            • 3. Re: Key Light
              Steven L. Gotz Level 5
              Use Keylight in After Effects and then export using the Quicktime Animation codec or a numbered series of TGA files. Then use the exported material in Premiere Pro.
