5 Replies Latest reply on Jan 28, 2008 11:16 PM by Harm Millaard
    Can't import full video
      I am trying to import some videos in premiere and it won't work fully. I import the videos but then I find that it only imports a small part of it. I have tried to import in After Effects to see if it would import fully there but it came up with the message "After Effects error: Error (4) reading frame from file "C:\documents and settings\James\My Documents\ORP raw\'08_01_27_00\08012701.avi". (86 :: 2) However, it still lets me import, but it does the same thing as premiere and doesn't import the whole video.
      I tried converting to a different format but it made the audio unsync.
      I was hoping someone could tell what the problem is or what I need to do.
      Jim
        • 1. Re: Can't import full video
          Harm Millaard Level 7
          Convert to DV AVI type2.
          • 2. Re: Can't import full video
            Hi Jim/Harm
            We had the output form a Morae session sent to us and are looking to Add credits etc in Adobe Premiere, but having the same issue with the file being imported only showing as 43 seconds when the actual video length is 15 mins and is an avi file:
            http://www.techsmith.com
            Uses their specific codec which may be half the problem?
            We are using Premiere Pro CS3
            Properties in Premier Pro from file:
            Type: AVI Movie
            File Size: 1.4 GB
            Image Size: 1280 x 1024
            Pixel Depth: 1280
            Frame Rate: 10.00
            Source Audio Format: 22050 Hz - compressed - Mono
            Project Audio Format: 48000 Hz - 32 bit floating point - Mono
            Total Duration: 00;00;43;13
            Average Data Rate: 33.2 MB / second
            Pixel Aspect Ratio: 1.0
            AVI File details:
            Contains 1 video track(s) and 1 audio track(s).
            Interleave: 1 : 9.86
            Video track 1:
            Size is 1.40G bytes (average frame = 163.91K bytes)
            There are 113 keyframes, 8912 delta frames.
            Frame rate is 10.00 fps
            Frame size is 1280 x 1024
            Depth is 32 bits.
            Compressor: 'tscc', TechSmith Screen Capture Codec
            Audio track 1:
            Size is 3.85M bytes
            Rate is 22050 samples/sec
            Sample size is 16 bits
            Compatible compressor: Microsoft GSM 6.10
            Compression ratio is 9.85:1
            GSpot 2.70a output:
            FILE_NAME Storyboard (1).avi
            FILE_NAME_WITH_PATH [Edited Ben Logan]FILE_SIZE 1,515,190,080
            CONT_AUDIO_STREAM_COUNT 1
            CONT_BASETYPE AVI(.AVI)
            CONT_BYTES_MISSING 0
            CONT_INTERLEAVE_ALIGN
            CONT_INTERLEAVE_PRELOAD
            CONT_INTERLEAVE_TIME
            CONT_SUBTYPE Multipart OpenDML AVI (2 parts),
            CONT_TOTAL_BITRATE 0
            VIDEO_ASPECT_CONVERT_AVI1
            VIDEO_ASPECT_CONVERT_AVI2
            VIDEO_ASPECT_CONVERT_CVD1
            VIDEO_ASPECT_CONVERT_CVD2
            VIDEO_ASPECT_CONVERT_DVD1
            VIDEO_ASPECT_CONVERT_DVD2
            VIDEO_ASPECT_CONVERT_SVCD1
            VIDEO_ASPECT_CONVERT_SVCD2
            VIDEO_ASPECT_CONVERT_VCD1
            VIDEO_ASPECT_CONVERT_VCD2
            VIDEO_ASPECT_SOURCE_MATCH
            VIDEO_ASPECT_TYPE_NTSC
            VIDEO_ASPECT_TYPE_PAL
            VIDEO_BITRATE 13393
            VIDEO_CODEC_NAME TechSmith Screen Capture Codec
            VIDEO_CODEC_STATUS Codec(s) are Installed
            VIDEO_CODEC_TYPE tscc
            VIDEO_DAR 1.250
            VIDEO_DURATION 15:02.500
            VIDEO_FIELDS_PER_SEC
            VIDEO_FRAME_COUNT 9025
            VIDEO_FRAMES_PER_SEC 10.000
            VIDEO_H264
            VIDEO_MPEG2
            VIDEO_MPEG2_3X2
            VIDEO_MPEG2_BFF
            VIDEO_MPEG2_I_L
            VIDEO_MPEG2_PPF
            VIDEO_MPEG2_PROG
            VIDEO_MPEG2_TFF
            VIDEO_MPEG4
            VIDEO_MPEG4_BVOP
            VIDEO_MPEG4_GMC
            VIDEO_MPEG4_NVOP
            VIDEO_MPEG4_QPEL
            VIDEO_PAR 1.000
            VIDEO_PICS_PER_SEC 10.000
            VIDEO_QF 1.022
            VIDEO_SAR 1.250
            VIDEO_SIZE_X 1280
            VIDEO_SIZE_Y 1024
            AUDIO_BITRATE 36
            AUDIO_BITRATE_TYPE
            AUDIO_CHANNEL_COUNT 1
            AUDIO_CODEC 0x0031 (GSM 6.10)
            AUDIO_CODEC_STATUS Codec(s) are Installed
            AUDIO_MPEG_STREAM_ID
            AUDIO_MPEG_SUBSTREAM_ID
            AUDIO_SAMPLE_RATE 22050
            Really could do with some help on this!
            Cheers
            Ben
            • 3. Re: Can't import full video
              Your source material and Premiere are causing problems. You may be better off with either better source material or a different editing environment.
              • 4. Re: Can't import full video
                Level 1
                Hi Harm
                I was hoping this would not be the case.
                I have sent a note requesting different source material from the company.
                Are the issues around the audio compression and the audio being Mono instead of Stereo?
                If we can't get this working in Adobe Premiere, can you suggest another piece of software where we can comp this together?
                Its a linear video with text on a full colour background breaking up sections of video. We are also adding simple audio effects on the top to keep it interesting.
                Cheers
                Ben
                • 5. Re: Can't import full video
                  Since the source codec is Techsmith, you may try Camtasia.
