1 Reply Latest reply on Nov 20, 2008 12:34 PM by Kevin Goldsmith
    Setting the width / height of the output image?
    mudxx
      I've created a Color Lookup Table (CLUT) that stores the data in a second image (so you've got one input image for the image to be filtered, and one that stores the CLUT... which basically acts as a work-around for importing an external array).
      The only problem is: Since the CLUT is 256 pixels wide, the output image is always AT LEAST 256 pixels wide (if the primary input image is wider, than this is no problem... otherwise, it's a problem).
      So... How can you define how large the output image is to be?
