6 Replies Latest reply on Feb 10, 2008 11:13 AM by Phil Griffith
    From PP to DVD - simpliest way ?
    Level 1
      Hi gentlemen,
      I have about 1 hour of video, on the timeline and with to burn out a test DVD of this footage.
      I chose the export function, then Adobe Media encoder -> MPEG2-DVD ......but PP wants to burn out a .m2v video file. ?? .... I want to burn a DVD, so why isn't Premiere wanting to burn out a series of .vob files ?
      I'm very puzzled here, as how to go about this. I don't want any menus, or chapters, just a test dvd for the time being.
      Very confused,
      Dave
        • 1. Re: From PP to DVD - simpliest way ?
          Jim_Simon Level 8
          Encore makes the .vob files out of the .m2v files from Premiere.
          • 2. Re: From PP to DVD - simpliest way ?
            Pro2 would directly create a simple DVD... Pro3 has Encore3 bundled and will no longer create a DVD by itself, you must use Encore3
            Some notes I made for myself a long time ago...
            Creating a SIMPLE movie in Encore3
            Create or Open an NTSC Project (usual blank is E3 on F: Drive)
            FileImport As Timeline, and select AVI File(s)
            Drag a Menu to the Project Panel
            In the Monitor-Menu Panel, Right Click and CLEAR unused Buttons
            In Project Right Click Menu and set as First Play
            In Flowchart Drag AVI to the Menu, set End Action to Last Menu
            In Monitor-Menu Right Click and hold the new Menu Item 1 and Drag to a new Location, then Right Click and Rename
            In Build Window
            Change the ISOs Name via the Browse function
            Click the Check Project and fix any errors
            Last step is to actually build the ISO File
            Burn the ISO with http://www.imgburn.com/
            Even Empty the DVD-ROM says it uses 526k usual overhead
            • 3. Re: From PP to DVD - simpliest way ?
              Mortimer IOU Level 2
              David --
              In PPro, pick the sequence timeline you want to make into a dvd, then
              File/Export/Export to Encore.
              You will get a new window. Pick direct burn without menus.
              • 4. Re: From PP to DVD - simpliest way ?
                shooternz Level 6
                As Jerry says ; fast and simple.
                Tip: a good way to write PAL project to NTSC DVD ( like I have to do frequently).
                Export timeline as an avi and open it in an NTSC Project then FILE>EXPORT> ENCORE
                I guess you could import the project and do the same.
                • 5. Re: From PP to DVD - simpliest way ?
                  If you're afraid to export/utilize Encore...
                  Pegasus makes a nice DVD authoring suite -- which (ack, don't laugh) actually will encode an MPEG-1 to a DVD format. (Saves time on the export if it's just to test playback).
                  You can download free software/trial versions on their website...forget the actual web addy, but you can get there via a redirect at www.tmpgenc.com
                  It's really as simply as exporting an MPEG-1 (Or multi-plexed MPEG-2) and pulling it into the program, build yourself a simple menu, save it, and burn it. Done. Less hassle and overhead (In my opinion) than encore.
                  • 6. Re: From PP to DVD - simpliest way ?
                    Phil Griffith Level 2
                    don't be afraid....Don't know why anyone would be. Encore is a very good dvd authoring and easy to use.
