1 Reply Latest reply on Feb 26, 2008 7:10 AM by Steven L. Gotz
    On project settings
      Hello all!
      Is it possible to change project settings in the Premiere start dialog and save those changes under the same setting? You have, for example, a setting called "Matrox HDV 1080i@25" and just want to change a single option in that setting and save it again as "Matrox HDV 1080i@25" in the same folder and not as "My own settings folder/My own HDV settings".
      Or could you alternatively anyhow cut those settings and paste them in the "Matrox HDV" folder? I am able to find all general settings (*.prpreset) in the Adobe/Premiere Pro CS3 folder but not the settings I generated later myself.
        • 1. Re: On project settings
          Steven L. Gotz Level 5
          You know where the default files are, but you can't find the ones you created in order to replace the originals?
          I suggest that you reconsider replacing the original, but if it is something you really want to do for reasons I don't understand....
          My newly created presets are in:
          C:\Documents and Settings\Steven\Application Data\Adobe\Premiere Pro\3.0\Settings\Custom
          Your's should be somewhere similar.
