0 Replies Latest reply on Nov 23, 2008 11:41 PM by Raju Rao
    XML object passing across sandbox bridge
    Raju Rao
      I am trying to convert a web-based Ajax application as a desk-top application.
      I need to use two applications due to high uses of javascript functions like eval, innerHTML etc which flout security restrictions of AIR. Hence I use two html loaders - the myRoot and myUI. The root has js code that accesses the AIR API to read data from the sqlite database and needs to pass the same to the main application.
      I setup the environment as suggested by the AIR development centre. However, I face a problem when trying to pass xml data object from the parent bridge to the child. If I convert the same to a string it works.
      Is there something specific to be done to pass xml objects?
      Thanks in advance,
      Rajnikant Rao
