3 Replies Latest reply on Aug 6, 2007 3:36 PM by (James_Jaeger)
    Installing CS3 Production Premium
    Level 1
      After feeding in the 4 installation disks, I get the following message:
      INSTALLATION/ RE INSTALLATION COMPLETED
      Successfully installed: 2
      Errors: 12 comonets
      It then lists the 12 apps that didnt install.
      Whats going on? Anyone know.
      James
        • 1. Re: Installing CS3 Production Premium
          Steven L. Gotz Level 5
          I had that problem and I finally went back to a restore point I trusted, deleted all references to any beta CS3 apps, and finally got everything to install.
          • 2. Re: Installing CS3 Production Premium
            Level 1
            Check the Windows Event Viewer for Errors generated by the MSI Installer. They should give some insight into what the problem is.
            • 3. Re: Installing CS3 Production Premium
              Level 1
              We did that and this showed error messages suggesting a problem with our DVD drive and/or the MS firewall so we tried a new load (after an uninstall) from another DVD drive and turned MS firewall off. Same problem. So called ADOBE and the suggested a workaround: pasting the installation disks into a folder and then installing from there. But prior to that we tried loading just one app at a time and system crashed with blue screen MS error message = PFN_LIST_CORRUPT so we're checking the memory first for a bad stick and we'll go from there after mem, bd and processor are tested. ADOBE also said it could be a bad installation disk and they said they will send a replacement set out right away if we want them to. If after successful memory check, we still have load problem I'll
              call for a replacement disk-set.
              Adobe tech support and customer service have been very good so far even though wait times are a little long.
              Thanks for input,
              James
