2 Replies Latest reply on Jul 8, 2008 6:14 AM by John T Smith
    problems with imoprt files into Adobe Premiere Pro
      Some days ago I bought and activated Premiere Pro CS3, but I can't work in it.I can't import media file with extension .mpg (linked clip) into Adobe Premiere Pro CS3. If I use the command File > Import in Adobe Premiere Pro, the file is imported without audio track. Import through Bridge (command "Place files") doesn't work. Double clicking the file in Bridge imports the file without the audio track as well. (Operating system Windows XP). As for the import the same failes into Encore CS3 is Ok. Can you help me? Is it defect or it can be corrected.
        • 1. Re: problems with imoprt files into Adobe Premiere Pro
          Eddie Lotter Level 4
          FAQ:Why is there no audio in my imported MPEG file?
          Cheers
          Eddie
          PremiereProPedia   ( RSS feed)
          - Over 300 frequently answered questions
          - Over 250 free tutorials
          - Maintained by editors like you
          Forum FAQ
          • 2. Re: problems with imoprt files into Adobe Premiere Pro
            Based on reading a LOT of problem reports, importing files from a DVD or hard drive camcorder or other MPEG device (including digital STILL cameras that create MJPEG files) or trying to edit divx, or Ripping DVD files rarely results in success in Premiere... do not be fooled by movie industry advertising into thinking that "DVD Quality Video" is suitable for EDITING... it is not... a DVD is designed to be for PLAYBACK only... and that includes trying to edit a Standard Def MPEG or VOB file!
            You should also use WAV sound files, not the compressed MP3 format
            The only SD (Standard Def) files that Premiere really likes are DV AVI type 2 (be sure you have type 2 and not DV AVI type 1 files)
            HD (High Definition) files are a completely different issue... I don't use HD, so can't say anything about editing those files
            Go to my notes page http://www.pacifier.com/~jtsmith/ADOBE.HTM
            Click the internal link for editing compressed files... read, there are some ideas & links there, including some links to other programs that have been mentioned in the Premiere forum as being better suited to editing MPG files... if you want to edit a divx file, start at http://www.divx.com/
            If you only have DVD type files, you should convert to DV AVI type 2 or use different software... go to the VideoHelp link in my notes and look for a program to convert... but do be aware that converting from a HIGHLY compressed viewing format back to an editing format is going to cause a drop in quality
            PS - To work with AC3 sound files in Premiere CS3, it MAY work to copy the ad2ac3dec.dll file from the Encore CS3 directory into the Premiere directory
