2 Replies Latest reply on Aug 1, 2008 6:06 AM by Eddie Lotter
    Restore deleted audio?
      So I unlinked a bunch of my tracks and deleted the audio portions of it (readying for some overdubs). I need those tracks back for now, and can't figure out how to "relink" the audio and video without finding each clip from the tape and bringing a fresh version into the timeline. Ideas???
        • 1. Re: Restore deleted audio?
          Colin Brougham Level 6
          Position the CTI (that blue upside-down triangle with the red line) at the beginning of the clip whose audio is missing. Make sure your track is active (ie. if Video 1 has the clip that needs audio, make sure its selector on the left of your timeline is lighter gray). Hit "M" on your keyboard; this will invoke the Match Frame command, which will open up the master clip related to the sequence clip in your source monitor. The CTI in the source monitor will be parked at the in-point of the instance of the clip; in fact, an in-point and out-point should already be set for the video portion of the clip. Right-click on the time bar and select Go to Clip Marker > Video In and then mark an Audio In, and then do the same for Video Out/Audio Out. Now your clip will have ins and outs for both video and audio, so simply edit over the unlinked video clip in the timeline. Don't use Replace Clip, as that will only replace video and won't add the audio.
          And yes, you'll need to do this for every clip. Hopefully, you don't have many to do :) In the future, simply mute the track, or select just the audio portion of the clips and right-click on them and deselect "Enable". It'll save you lots of time... next time :D
          • 2. Re: Restore deleted audio?
            Eddie Lotter Level 4
            You will also find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
            Cheers
            Eddie
            PremiereProPedia   ( RSS feed)
            - Over 300 frequently answered questions
            - Over 250 free tutorials
            - Maintained by editors like you
            Forum FAQ
