4 Replies Latest reply on Sep 11, 2008 12:37 PM by shooternz
    Dual Display
      Is there anyway to setup Premiere Pro to use dual display?
        • 1. Re: Dual Display
          shooternz Level 6
          Yes. No problem at all if you have the video card to manage it.
          • 2. Re: Dual Display
            SFL46 Level 3
            Kim
            If you have dual screens hardware, the Premiere main page appears on the primary monitor. To use the other monitor, simply drag the panels you want to the second screen and size as you desire. Don't drag the main workspace--leave that on the primary. Premiere always displays dialogs and message at the screen center. SO, if you have the main page dragged over two screens, these dialogs will be split across your two screens. So, just move the panels.
            Although Premiere will save this workspace between program starts, you will want to save a custom workspace just in case you inadvertently select the reset.
            • 3. Re: Dual Display
              Level 1
              Thanks, Steve
              I was hopeing that I could extend the timeline.
              Kim
              • 4. Re: Dual Display
                shooternz Level 6
                You can have the timeline extended across two monitors if you choose.
                Dock it in its own panel and stretch it out.
