2 Replies Latest reply on Sep 22, 2008 1:34 PM by Andrey V
    Ripple Edit - how come it doesn't adjust audio correctly ?
    Level 1
      Can somebody help me with the ripple edit tool ?
      When I use ripple edit on a portion of video, the audio does not
      also adjust itself, so when I play back the video, the audio is not
      in the correct place anymore.
      Why is this happening ?
      Thank you,
      Dave.
        • 1. Re: Ripple Edit - how come it doesn't adjust audio correctly ?
          Harm Millaard Level 7
          If there is no room on unlocked audio tracks to perform the ripple edit, that happens. Lock the audio tracks without room and then perform the ripple edit.
          • 2. Re: Ripple Edit - how come it doesn't adjust audio correctly ?
            Andrey V Level 2
            When you use a ripple edit tool, if the tracks are not linked together, select audio and video track and you will get adjustment of both. If your audio and video are linked together you could press and hold Alt key select one of the tracks, and you will get ripple edit on only tracks, but the other will stay where its at.
            If your audio or video tracks are locked up and you will perform ripple edit then all time line material will shift and after unlocking you will see at the beginning of every clip a red murk telling how far of sync you have shifted each clip time code - its no good. You will have to go to every clip and right click on every red murk and chose to "move to sync" and it is a pain.
