1 Reply Latest reply on Sep 22, 2008 7:51 PM by Leonard King
    exporting using youtube preset gives flicker
      I am trying to do a simple 3 minute video using the youtube preset. the finished video after taking 40 minutes to export is flickering. I tried turning off the de-interlace that didn't work. Any suggestion. With a 40 minute export time I really don't have the time to experiment with any more settings. By the way, I have used these settings before with no problem and a much shorter export time. I can't think of any thing that has changed.
      by the way why is there no search box for this forum.
        • 1. Re: exporting using youtube preset gives flicker
          Level 1
          Hi Jes.
          There's no Search box as such, but there is a "Forum Search" link in the navigation menu just above this topic.
          The YouTube preset uses H.264 so it is going to be a slow encode, but 40 minutes for a 3 minute video strikes me as excessive.
          Have you changed the preset in any way?
          How complex are the effects and compositing in your sequence?
          I should check whether your source material is NTSC, like the preset. A frame rate jump may cause problems similar to what you've mentioned.
          Another question would have to be, what is your source format?
