6 Replies Latest reply on Sep 25, 2008 1:10 PM by Steven L. Gotz
    Karaoke Text
      Is there any easy way to create karaoke text in Premiere Pro CS3?
        • 1. Re: Karaoke Text
          akribie Level 2
          Depends what you mean by easy.
          CS4 adds speech to text, which might be helpful.
          Otherwise, an addin like http://www.dvdate.ru/en/dvsubtitles.html might prove less tedious than creating loads of individual titles by hand.
          • 2. Re: Karaoke Text
            Eddie Lotter Level 4
            See also: FAQ:How do I create subtitles/karaoke lyrics?
            Cheers
            Eddie
            PremiereProPedia   ( RSS feed)
            - Over 300 frequently answered questions
            - Over 250 free tutorials
            - Maintained by editors like you
            Forum FAQ
            • 3. Re: Karaoke Text
              Steven L. Gotz Level 5
              It is easy enough to create titles, but coloring each word either requires a title per word, or you can do it the way I used to do it, which is make the text transparent and then use a colored box on behind it yo highlight each word. And then both layers sit on top of a third, solid, layer.
              I have a collection of titles from one letter to 20 letters that I created to handle the task.
              Of course, now I just animate the text in After Effects. Much easier.
              • 4. Re: Karaoke Text
                Dan Isaacs Level 2
                Steven's suggestions are good.
                You could also try having just two titles for each line : one normal and one highlighted and using cropping or masks to hide the highlights until they needed.
                Sorry, but I can't resist the quote:
                "Karaoke weekend at the suicide shack, community service and I'm still the mack."
                • 5. Re: Karaoke Text
                  Level 1
                  Thanks a lot for all your replies. So, is that mean animating the text in After Effects is much easier than Premiere Pro? If so, how to do it in After Effects?
                  • 6. Re: Karaoke Text
                    It is much easier.
                    Here is a tutorial to help you get started:
                    http://cowcast.creativecow.net/podcast/per-character-3d-text--13
                    and then this one for more details:
                    http://library.creativecow.net/articles/rabinowitz_aharon/CC_Text_2.php
                    You need to animate the color of the "area of effect".
                    Also, you can actually change the "value" of the text itself by animating the text parameter.
