14 Replies Latest reply on Aug 31, 2009 2:24 PM by Harm Millaard
    error trying to capture
    Level 1
      I've seen several posts mention that people open premiere, click capture and get the following two errors:
      premiere pro debug event, premiere pro encountered an error
      [..\..\Src\TextPopup.cpp-273]
      and then the same note with
      [..\..\Src\HotTimecodeControl.cpp-387]
      I'm having this exact same problem with a panasonic PV Gs500. If I click ok through the two error messages I get the capture screen, but I can't control the camera from the computer and I can't capture a recording if I use the camera controls to play the tape.
      I'm on XP pro servicepack 2
      pentium D 3ghz with 3.25 ram
      currently have 280gb free on the drive
      soundblaster audigy
      I've searched all over and I just see people having the same problem, but no one finding the solution. can anyone help?
      thanks
      Mark
        • 1. Re: error trying to capture
          Eddie Lotter Level 4
          The problem is that none of the technically adept people on this forum are experiencing this problem, so it's next to impossible to diagnose. What troubleshooting have you done?
          Cheers
          Eddie
          Forum FAQ
          Premiere Pro Wiki
          - Over 250 frequently answered questions
          - Over 100 free tutorials
          - Maintained by editors like you
          • 2. Re: error trying to capture
            Level 1
            I am having the same problem can anyone help????
            Cannot seem to capture footage in premiere cs3....just gives debug error?
            Sonder!
            • 3. Re: error trying to capture
              Can you capture in Window Movie Maker?
              • 4. Re: error trying to capture
                Miles Johnston
                CS3 Capture has crashed out on me many times, so I have use 1.5, and transfer from that.
                It has happened a number of times now.
                I can set up to capture, and set up to capture on any of the other drives makes no difference.
                Using Fire wire to either the Canon XL 2, or the SONY Mini DV /DVCAM Player/recorder, or the JVC MiniDV-SVHS.
                All work in 1.5, CS3 crashes.
                Re-Installing all the software is a major bind. Will try again, after I finish this major 7 hr project
                Running XP SP2
                4G RAM
                Hyperthreading P4
                Upgrade from PP 1.5, to CS3
                using Canopus 2 and upgrade to 3
                Main, AV, and Export Drives, and a band of SCSIs for internal storage
                with a few USBs for safety.
                • 5. Re: error trying to capture
                  Level 1
                  I am getting both of these errors also.
                  Is there a solution or fix? am I missing something like a patch or update somehow?
                  • 6. Re: error trying to capture
                    Since you haven't provided any details we don't know.
                    Please provide these details to help us help you.
                    Cheers
                    Eddie
                    • 7. Re: error trying to capture
                      Level 1
                      im running windows vista 32bit
                      premiere cs3
                      3 gigs ram
                      320gig ata drive
                      pent core 2 quad 2.66
                      This laptop is not on the world wide web 95% of the time due to my travels. that being said I could be lacking some MS and Adobe updates/patches. I would have thought that it would work out of the box but no such luck. I have seen other people with this same error. I would think that the resolution sould be the same or vary similar. Does anyone know what the error codes mean? any help or pointing in the proper direction would help
                      • 8. Re: error trying to capture
                        You provided about 5% of the details I asked for.
                        That's okay. I'll just move along.
                        Cheers
                        Eddie
                        • 9. Re: error trying to capture
                          Lionsvic Level 1
                          I AM FACING THE SAME CAPTURE PROBLEM WITH THE SAME CODES POPPING UP ON MY SCREEN WHILE TRYING TO CAPTURE VIDEO FROM MY PANASONIC AG-DVX100A : ( So far i've only tried to capture in all the modes: 60i/30p/24p
                          I just purchased the HP HDX16 notebook
                          Specs:
                        • Intel Centrino 2 Processor Technology featuring Intel Core 2 Duo Processor P7550, Nvidia GeForce GT 130M with 1 GB dedictated graphics memory
                        • 4 GB DDR2 RAM (2 Dimm) (8 GB Maximum)
                        • 500GB (5400RPM) Hard Drive (SATA), SuperMulti 8X DVD±R/RW with LightScribe and Double Layer Support
                        • Genuine Windows Vista Home Premium 64-bit edition with Service Pack 1
                        • 16 inch Diagonal High Definition HP BrightView Infinity Display (1366×768)
                          I am able to capture video on Windows Movie Maker and other cheap programs that came with my laptop!! but not on Premiere Pro CS3!? I find that ridiculous : (
                          What could be the problem? My Nvidia card? OR WINDOWS VISTA?!! SHOULD I DOWNGRADE TO XP PROFESSIONAL?
                          I've spent all day today searching online and it looks like a lot of people have been reporting the same issue, however most of the post date back to THE YEAR 2007!! So I assume there has to be a patch or a solution to this problem by now (I HOPE : )
                          PLEASE SOMEON HELP. I'M VERY FRUSTRATED. I CAN'T START ON MY PROJECTS UNLESS I FIND A SOLUTION SOON!
                          ALL THE HELP WOULD BE MUCH APPRECIATED. Thax in advance....
                          Vic
                          cinercon@ymail.com
                          • 10. Re: error trying to capture
                            Lionsvic Level 1
                            Hey Steve:
                            Just wondering, did you finally find a solution to this issue?
                            I'm experiencing the same thing.
                            I hope you can help me with some solutions if you've resolved this problem...
                            Best regards,
                            Vic
                            • 11. Re: error trying to capture
                              Harm Millaard Level 7
                              Try to capture with HDVSplit instead of with CS3. It is freeware and does a much better job than CS3.
                              While you are at it, get at least 2 eSATA 7200 disks. A single slow (5400) disk is not enough and the processor does not help either. If you are clever, only try to edit SD material. In that case (downrez in camera) try capturing with Scenalyzer.
                              • 12. Re: error trying to capture
                                Lionsvic Level 1
                                Thax for the advise, Harm:
                                All I want to capture is Standard Definition DV...NO HD! The DVX100A only captures regular DV anyway.
                                So do you think this problem lies with my Hard Drive type?
                                So should I still get 2 eSATA disks for my PC? I just bought it so i might as well exchange it for a new one that has 2 eSATA disks.
                                Thank you again,
                                Vic
                                • 13. Re: error trying to capture
                                  Lionsvic Level 1
                                  I forgot to add that I have NO PROBLEMS capturing video with other programs that were included in my notebook...so then is it possible that having 2 eSATA disks is not necessary for SD DV?
                                  VIC
                                  • 14. Re: error trying to capture
                                    For capturing your single disk will be enough, for instance with OL, but for editing you need the extra disks.
