4 Replies Latest reply on Oct 26, 2008 10:02 PM by Dan Isaacs
    HD versus SD monitors
      I am having no luck in being able to display a color corrected version of an HD project without spending a small fortune. I've found a few rentals for field monitors that are HD, but do any of you know, if I export a SD version of the film, is there a difference RE: Color Correction between the two formats? I've got an excellent SD monitor I can use, but if the difference is significant then I will look into seeing what HD options i have.
      Thanks in advance.
      H.R. "Roach" Crystal
        • 1. Re: HD versus SD monitors
          Jim_Simon Level 8
          I can't say from experience, but SD and HD do use different color gamuts, with HD having more colors available. Which means downconverting to SD you will lose some of the HD color range.
          • 2. Re: HD versus SD monitors
            Dan Isaacs Level 2
            Mehhhhh... Not so much. The gamuts are actually not so far apart in size -- just "different". I remember reading something about this: Apparently, when ITU was debating the ratification of the new "709" standard, there were a lot of delegates who were saying (mainly the Brits, I think) "What a minute... this will just confuse the hell out of people and it won't really improve anything. Why bother?". But, it passed anyway and now here we are with two different standards, neither much better than the other and everybody is completely confused.
            There should be, but there is not: Premiere CS3 essentially ignores the fact that there are two different color standards and processing everything as "601". It does not convert 709->601, it just pretends they are one and the same.
            So, the values you'll see when exporting as SD will be identical to the HD output, but it will appear somewhat incorrectly on SD monitors.
            It is a bug.
            You may want look at my HD->SD workflow, which fixes the problem for HD footage. Unfortunately, as I am only doing post-processing of the color, RGB graphics will still be incorrectly converted... but that's (usually) not as big of a deal.
            This has been fixed (though I have yet to test it thoroughly) in CS4.
            • 3. Re: HD versus SD monitors
              Jim_Simon Level 8
              I'm not ready to agree with that one just yet. The colors I see in HD broadcasts or on Blu-ray surpass anything I've ever seen on SD.
              • 4. Re: HD versus SD monitors
                Dan Isaacs Level 2
                Well, not exactly the info I was looking for, but it's something on the subject:
                http://www.glennchan.info/articles/technical/hd-versus-sd-color-space/hd-versus-sd-color-s pace.htm
