1 Reply Latest reply on Dec 3, 2008 3:28 AM by (LucyXerge)
    Illustrator Artwork Artifacts
      Hello.
      When I import Illustrator CS3 artwork into Premiere, some of the artwork has little dotted artifacts within the boundary of the clip. It doesn't affect all the artwork, just random ones.
      I've tried turning the compression on and off when saving the Illustrator file, which made the artifacts disappear on some clips, but not others!
      Does anyone know what is causing this?
      Many thanks.
        • 1. Re: Illustrator Artwork Artifacts
          Level 1
          Hmmmm. Just figured something out.
          If I open up one of the affected clips in Illustrator, draw a box under the artwork and delete it again (just to activate the Save function), resave the artwork, then go back into Premiere, when the clip updates, the artifacts disappear. If I do the above again, the artifacts return!!!
          What on Earth is going on?
