33 Replies Latest reply on Aug 31, 2007 3:47 AM by (BIJU_PAUL)
    Replace clip bugs the filter
      If you apply the new option of CS3 Replace Clip(Windows) to a clip on the timeline, Its works fine, if there are no filter with keyframe attached to the replaced clip. Else the effect will be there on the effects control but simply will not work, even if you make it on and off. If you try to modify any attribute of that filter then effect will be active on the new clip.
      Any one else faced the same? Is it a known bug? Any solution?
