3 Replies Latest reply on Jan 13, 2009 8:26 AM by Harm Millaard
    import failure - error message 1231
    bojesen Level 1
      I have successfully imported a number of mp4 files (in folders with other source material from Sony XDCAMEX - PMWEX3). One of the files was mistakenly deleted from the project window.I have unsuccessfully tried to reimport it several times but an error message is displayed: (Drusilla/pro/3.2.0/MediaCore/ASL/Foundation/Make/Mac/../../Src/Mac/MacFile.cpp-1231).
      On another - (may be not connected) -occasion I got error message (Drusilla/pro/3.2.0/Libraries/UIFramework/Make/Mac/../../Src/TimeBarControl.cpp-1231).
      Any ideas, please?
        • 1. Re: import failure - error message 1231
          Eddie Lotter Level 4
          Please provide these details to help us help you.
          Cheers
          Eddie
          PremiereProPedia   ( RSS feed)
          - Over 300 frequently answered questions
          - Over 250 free tutorials
          - Maintained by editors like you
          Forum FAQ
          • 2. Re: import failure - error message 1231
            bojesen Level 1
            Thank you for your response. In the meantime I believe I have found the - or at least an answer - to the problem. In the project described, the file in question appeared to be imported three times: xxx-1, xxx-2 and xxx-3. As these appeared to be the same, I deleted files xxx-2 and xxx-3 in the project window and the relevant folders in the BPAV/CLPR folder. I did not link this action to the subsequent problem, as described in my original post.
            Working on a new project, one file was again imported three times, as described above. Deleting xxx-2 and xxx-3 as above (but NOT emptying the wastebasket), xxx-1 subsequently showed offline. However, it again showed online as soon as folders xxx-2 and xxx-3 had been replaced in the BPAV/CLPR folder.
            It appears that some faulty content in xxx-1 is attempted rectified in xxx-2 and successfully in xxx-3.Without the two latter folders available xxx-1 will not import.
