2 Replies Latest reply on Jan 12, 2009 7:19 AM by (Chris_Jamros)
    CS3 Freezing during HDV capture from Sony HVR-Z1U
      I am running Premiere CS3.2.0 on a MacBook Pro 2.4GHz Intel Core 2 Duo w/ 4GB RAM, running OS 10.5.5.
      While attempting to capture HDV footage from my Sony HVR-Z1U, Premiere freezes...necessitating a hard shut-down and restart. The freeze happens anywhere from 5 seconds into capture to 1:30 into capture.
      Camera connected via Firewire (of course). Capture settings NTSC, Sony, Standard, Drop-Frame.
      Project settings: general HDV 1080i (60i).
      I have tried capturing to internal hard drive, eSATA external striped drive w/600GB free space, Firewire 800 external drive w/ 1.2 TB free space, USB2 external drive w/ 1.8TB free space...all with the same result.
      This problem is persistent...the only variable is the length of time before the crash.
      I had this problem in November as well and eventually gave up. After that, I did, however, do a clean install of OSX and all software to no avail. I only updated OSX to 10.5.5 thinking that 10.5.6 had perhaps been the problem...t'wernt that easy.
      I have tried deleting preferences files and preset files, to no avail.
      I captured successfully with this combination of equipment before...back in June. Anyone know of any software updates that may have introduced this glitch since then?
      Thank you, anyone, for any help you can offer.
      C.
        • 1. Re: CS3 Freezing during HDV capture from Sony HVR-Z1U
          Jim_Simon Level 8
          That one's been bugging me lately. Technically it's ATSC. I wish these camera and software makers would recognize that.
          OK, sorry. Had to get that off my chest.
          • 2. Re: CS3 Freezing during HDV capture from Sony HVR-Z1U
            Level 1
            Also, I forgot to include earlier, when Premiere initializes/starts up the following messages appear in the console: (I apologize if this is superfluous gak, but for the life of me in all my research I can't find out if these messages are critical or ignorable...similar messages appear when i start other Adobe applications):
            1/11/09 8:00:02 PM [0x0-0x16016].com.adobe.AdobePremierePro[152] objc[152]: Class EpicJSWindowExternalHandler is implemented in both /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_registration.framework/Versions/A/adobe_regist ration and /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_personalization.framework/Versions/A/adobe_per sonalization. Using implementation from /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_personalization.framework/Versions/A/adobe_per sonalization.
            1/11/09 8:00:02 PM [0x0-0x16016].com.adobe.AdobePremierePro[152] objc[152]: Class EpicWizardController is implemented in both /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_registration.framework/Versions/A/adobe_regist ration and /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_personalization.framework/Versions/A/adobe_per sonalization. Using implementation from /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_personalization.framework/Versions/A/adobe_per sonalization.
            1/11/09 8:00:02 PM [0x0-0x16016].com.adobe.AdobePremierePro[152] objc[152]: Class EpicPanel is implemented in both /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_registration.framework/Versions/A/adobe_regist ration and /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_personalization.framework/Versions/A/adobe_per sonalization. Using implementation from /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_personalization.framework/Versions/A/adobe_per sonalization.
            1/11/09 8:00:02 PM [0x0-0x16016].com.adobe.AdobePremierePro[152] objc[152]: Class EpicController is implemented in both /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_registration.framework/Versions/A/adobe_regist ration and /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_personalization.framework/Versions/A/adobe_per sonalization. Using implementation from /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_personalization.framework/Versions/A/adobe_per sonalization.
            1/11/09 8:00:02 PM [0x0-0x16016].com.adobe.AdobePremierePro[152] objc[152]: Class EpicJSWindowExternalHandler is implemented in both /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_personalization.framework/Versions/A/adobe_per sonalization and /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_eula.framework/Versions/A/adobe_eula. Using implementation from /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_eula.framework/Versions/A/adobe_eula.
            1/11/09 8:00:02 PM [0x0-0x16016].com.adobe.AdobePremierePro[152] objc[152]: Class EpicPanel is implemented in both /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_personalization.framework/Versions/A/adobe_per sonalization and /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_eula.framework/Versions/A/adobe_eula. Using implementation from /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_eula.framework/Versions/A/adobe_eula.
            1/11/09 8:00:02 PM [0x0-0x16016].com.adobe.AdobePremierePro[152] objc[152]: Class EpicController is implemented in both /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_personalization.framework/Versions/A/adobe_per sonalization and /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_eula.framework/Versions/A/adobe_eula. Using implementation from /Applications/Adobe Premiere Pro CS3/Adobe Premiere Pro CS3.app/Contents/MacOS/../Frameworks/adobe_eula.framework/Versions/A/adobe_eula.
