5 Replies Latest reply on Jan 15, 2009 2:52 PM by the_wine_snob
    Keying: allow white text to show through?
      I have two identical DV clips except that:
      Clip1 has better resolution (or looks better)
      Clip2 has more compression artifacts, and has white text caption in the lower 1/3 of the screen.
      I want to combine the two so that I get clip3 that has the better resolution in most of the area PLUS the text caption. Obviously the text and perhaps the immediate surrounding area would be in lower resolution; that's ok.
      I can't figure out what type of keying is needed to make this happen. It's not quite the same as green screen keying.
      I'm using premiere pro 1.5. If you have a solution for CS3 it would probably help me.
