1. Re: P2 1080i/24p and CS3
Colin Brougham Jan 16, 2009 9:22 AM (in response to asflyboy)That seems odd. I've never had any issues mixing the same footage and project preset. The only thing I can think of is if you shot 24p instead of 24pA, and I'm not even sure that would create the need for a render.
What happens if you drop the files in a DVCPROHD 1080i/60i project? -
2. Re: P2 1080i/24p and CS3
R-Cole Feb 18, 2010 10:00 PM (in response to Colin Brougham)I noticed the same issue while running some tests today. I shot 6 x 30 second clips to p2. 1080i 24p, 1080i 24pa, 720p 24p, 702p 24pn, DVCPro 50 480i 24pa, DVCPro 50 480i 24p. I created 3 sequences, one for each of the resolutions.
On the 1080i sequence the 24p requires rendering while the 24pa does not. Same thing for the DVCPro 50, the 24p requires rendering while the 24pa does not. None of the 720 clips required rendering and neither of those were shot in 24p advance.
I am very interested to find out why this is happening.
3. Re: P2 1080i/24p and CS3
shooternz Feb 18, 2010 11:50 PM (in response to R-Cole)Are you guys using P2 Project presets or DVCProHD Project presets?
4. Re: P2 1080i/24p and CS3
R-Cole Feb 19, 2010 5:11 AM (in response to shooternz)For the 2 HD formats I opened a sequence in DVCProHD at 24p using the matching resolution for each. The SD footage was placed into a DVCPro50 sequence for 24p. The only common denominator is that the 2 that required rendering right away were interlaced (1080i & 480i) resolutions. I am trying to decide which format will serve me best for a project that needs to be delivered in HD (Vimeo) and SD (DVD) and it is not off to a good start if some need rendering right away. Or it is just that much more obvious that I should select the 24PA format regardless of the resolution.
5. Re: P2 1080i/24p and CS3
shooternz Feb 19, 2010 1:52 PM (in response to R-Cole)You are only rendering preview files for the timeline so unless its taking a massive amount of time..why are you worrying?
6. Re: P2 1080i/24p and CS3
R-Cole Feb 19, 2010 2:24 PM (in response to shooternz)Time is a part of the reason. Mostly I want to narrow down a recording format that suits my needs (HD for the web & SD for DVD) in the most efficient way possible. It just threw me when I dropped the footage into what seemed to be the correct sequence setting and it needed rendering before making any adjustments.
