5 Replies Latest reply on Jan 17, 2009 1:39 PM by the_wine_snob
    Big Projects and Load Time
      I have a project that uses Sony EX1 footage, with an SD widescreen pre-set. The HD footage imports fine and does its "conforming" routine, and I can usually edit without problems, even I have to do a lot of "render work sequence." The project will ultimately be about 55 minutes and it draws on 35 gigs of original footage.
      I've noticed that the bigger the project gets, the more unstable it seems and, in particular, the longer it takes to load at start-up. I can load the project and then come back in 12-15 minutes to start working. Is there a project or preference setting that would reduce this wait time?
