This content has been marked as final.
Show 12 replies
1. Re: Audio is unsynced after encoding
JSS1138 Jan 27, 2009 6:05 PM (in response to director.lionel)What do you use to create the MPEGs? -
2. Re: Audio is unsynced after encoding
director.lionel Jan 27, 2009 7:36 PM (in response to director.lionel)I used the Adobe Media Encoder that comes with CS3. -
3. Re: Audio is unsynced after encoding
Jeff Bellune Jan 27, 2009 7:40 PM (in response to director.lionel)Then export elementary streams, if that's what works. -
4. Re: Audio is unsynced after encoding
director.lionel Jan 27, 2009 7:48 PM (in response to director.lionel)Can you tell me what are elementary streams and how I would export them? -
5. Re: Audio is unsynced after encoding
Jeff Bellune Jan 27, 2009 7:49 PM (in response to director.lionel)You already did that when you exported to separate video and audio files. -
6. Re: Audio is unsynced after encoding
director.lionel Jan 28, 2009 12:24 AM (in response to director.lionel)I need to send trailers to others (for general viewing), so I assume I need to keep them multiplexed mpeg files for viewing in RealPlayer or Qucktime player. If you know otherwise, please let me know. Thanks. -
7. Re: Audio is unsynced after encoding
Jeff Bellune Jan 28, 2009 4:02 AM (in response to director.lionel)For web delivery, Flash and Windows Media are much better choices than MPEG2.
If you'll be sending them physical media, then just author and burn a DVD using the .m2v and .wav files. -
8. Re: Audio is unsynced after encoding
Stan Jones Jan 29, 2009 6:50 AM (in response to director.lionel)> I need to send trailers to others (for general viewing)....
I didn't see the following point specifically made in this thread or your parallel thread in the Encore forums, where I think you said you are emailing the trailers. It has been a while since I have received an actual movie attached to an email; put the trailer on the web and send a link in the email. Then use flash for the trailer. -
9. Re: Audio is unsynced after encoding
director.lionel Jan 29, 2009 4:28 PM (in response to director.lionel)I will eventually be putting the trailer onto websites, but I wanted to avoid making them public until I think they're ready. There's certain individuals I'd like to send the trailer directly. It would also be a hassle and expense to send it to 30 people via separate DVDs, just to get their input.
Is it possible to attach and send a flash file via email? -
10. Re: Audio is unsynced after encoding
Jeff Bellune Jan 29, 2009 4:52 PM (in response to director.lionel)>Is it possible to attach and send a flash file via email?
Just put it on a private portion of your web site (or your favorite hosted web site) and only give the link to the individuals who need to see it initially. -
11. Re: Audio is unsynced after encoding
Stan Jones Jan 29, 2009 4:54 PM (in response to director.lionel)Or you can use Vimeo and set the privacy setting to require a password. -
12. Re: Audio is unsynced after encoding
director.lionel Jan 29, 2009 9:36 PM (in response to director.lionel)Thanks for the ideas, guys.
