10 Replies Latest reply on Sep 2, 2008 10:51 PM by jt643
    Open Browser Window Problems
    jt643
      I am using the built-in functionality in DW to open a new browser window from text. I have multiple links on my page that each open a different media file. I am using the SAME window name so that the user does not have to have multiple windows open in case they want to view or listen to all of the media files on the page.
      The page works great and loads whichever media file I click in a new browser. HOWEVER, when I close out of that window, after about a minute, the next media file automatically pops up in a new window and begins to play!!!
      HELP!!!
        • 1. Re: Open Browser Window Problems
          Level 7
          so you click a link, it opens a new window named "media"
          Then you close the media window.
          then you click another link, and a new window named media is opened.
          is that what's happening? It's what is supposed to happen.
          Alan
          Adobe Community Expert, dreamweaver
          http://www.adobe.com/communities/experts/
          • 2. Re: Open Browser Window Problems
            jt643 Level 1
            One additional item...my page gains a number sign after I close out of my initial media window...could that be an indication of what is causing my issue?
            i.e. mypage.com/downloads
            then
            mypage.com/downloads#
            • 3. Re: Open Browser Window Problems
              Level 7
              example.com/downloads#
              is because of the way you made the link.
              as-is:
              Click <strong><a href="#"
              onclick="MM_openBrWindow('shepherds.html','media','width=600,height=465')">h
              ere<
              /a></strong> to play.<br />
              change to this:
              Click <strong><a href="javascript:;"
              ere<
              or better:
              Click <strong><a href="shepherds.html" target="media"
              onclick="MM_openBrWindow('shepherds.html','media','width=600,height=465');
              return false">here<
              Note the ; return false added after the js event handler, to prevent the
              href link from being followed if JavaScript is active.
              If JavaScript is not active, the href link is used.
              Alan
              • 4. Re: Open Browser Window Problems
                jt643 Level 1
                This is great! Thanks for taking the time. While I check to see if that resolves it, I figured I would answer your question to provide clarity.
                I click the link and the file opens in a window called 'media.' Everything works great in that window. Then, when I close 'media' and navigate back to the original page where I first clicked the link, the 'media' window opens again with the next file - WITHOUT me clicking anything! It just keeps popping up a new window as long as the page with all the media links is still open.
                I hope this provides clarification. I will try your code. Thanks again.
                • 5. Re: Open Browser Window Problems
                  Level 7
                  We will need to see the page - can you send us a url?
                  E. Michael Brandt
                  www.divahtml.com
                  www.divahtml.com/products/scripts_dreamweaver_extensions.php
                  Standards-compliant scripts and Dreamweaver Extensions
                  www.valleywebdesigns.com/vwd_Vdw.asp
                  JustSo PictureWindow
                  JustSo PhotoAlbum, et alia
                  • 7. Re: Open Browser Window Problems
                    Level 7
                    I've been unable to replicate the trouble you have described, not in IE
                    or FF. Can you tell me the specific links I ought to click?
                    E. Michael Brandt
                    www.divahtml.com
                    • 8. Re: Open Browser Window Problems
                      jt643 Level 1
                      how i reproduce the issue is that i click the first 'here' link on the "Shepherds' Conference" video. The media window opens, and everything works great. When i close the window, the next media file (Part 1 mp3) opens after about a minute or two automatically - nothing clicked - as long as that particular page is open.
                      I hope this helps.
                      • 9. Re: Open Browser Window Problems
                        Level 7
                        > great.
                        Do you mean use the Back button to return to the downloads page?
                        which page? the downloads page?
                        > I hope this helps.
                        I did use the BAck button to return from the media page to the downloads
                        page, waited, and nothing else opened, in FF.
                        E. Michael Brandt
                        www.divahtml.com
                        • 10. Re: Open Browser Window Problems
                          jt643 Level 1
                          Sorry for the delay...I have tried recreating my problem, but it is working correctly! I am posting my new site with the code tonight. I will post the results. Thanks.
